Author Topic: Key Fob battery dead.  (Read 2784 times)
unlucky alf
  • worksop, notts
Re: Key Fob battery dead.
« Reply #15 on: 04 February 2009, 16:02:27 »
when you say no light are you refering to the led? have you put the battery in the correct way up?, i know it sounds a silly question but when i done mine the battery dropped out so wasnt sure which way up it went ;)
Scorpio
  • Cambs:
« Reply #16 on: 04 February 2009, 17:42:41 »
Thank you Tim, An easy thing to do. I am sure it is right, but I have to check it out. A simple job that can go wrong ??  Yes, it is the light on the key that shows it is working. I know the Battery is correct and thought it would be a simple swap. Will let you know the result.
« Reply #17 on: 04 February 2009, 19:06:58 »
you need to re-programme the key.
Put it in the ignition and turn ignition on.
press one of the fob buttons for a few seconds.
the doors should lock and unlock
The key is then programmed. :y
Scorpio
  • Cambs:
« Reply #18 on: 04 February 2009, 19:57:03 »
Hi All, The key is working ok now. The end fault was, I had to pack the battery out to make Contact and now the light comes on.
Such a simple fault, but easily remeided. Hurray!  This may well help othere's.  When fitting another Battery, make sure the light works before closing the key, by holding the battery in.
Scorpio
  • Cambs:
« Reply #19 on: 04 February 2009, 20:09:11 »
Hi Albitz, Thank You. Have just tried the key which was not very positive and using your advice, it now works well. This must happen a lot,  to othere's when the battery gives up. Hope this helps for antone in the future. Thanks again.
« Last Edit: 04 February 2009, 20:10:14 by Scorpio »
