Author Topic: What is the real func of sec air injection system?  (Read 5508 times)
Re: What is the real func of sec air injection system?
« Reply #15 on: 04 February 2009, 21:28:57 »
Well, it was required to pass Euro2 emissions, so I guess something was done to still pass the later Euro emission codes.
yep went twin cats and dbw throttle and cpp :y
None of those would affect emmissions....
Any improvement in emmissions must be done on the management side, though NOX reduced by lower compression ratio (rather than EGR)
« Reply #16 on: 04 February 2009, 21:30:59 »
AFAIK, at least the 2.2 hasn't got it. I'm a bit curious what replaced it though. Better engine management, or some pre-cat on the down tube or something?
Correct, small pre-cats......these heat up much faster and hence no air injection......just an emission light that comes on when the pre-cats get tired!
Martin_1962
« Reply #17 on: 05 February 2009, 08:58:40 »
And what's wrong about reducing the CO and HC emissions?
At the cost of more pollution making the kit, extra energy to drive it, extra fuel to carry it around - I reckon it is a waste
Matchless
  • Nottingham
    • A white van
« Reply #18 on: 05 February 2009, 10:04:31 »
afaik, there was a proposal to introduce a new emissions requirement where the total emissions from key-turn through a simulated urban drive was to be capured and measured but pressure from the US got it blocked.
In response, Vx fitted the secondary air injection to the Omega which would reduce HC emissions  by oxidising (burning) unburnt fuel in the manifold and down pipes and help the cats get to operating temperature more quickly.
Ford and Jaguar were both experimenting with massive 3-phase (AC) alternators on engines at Nottingham University, the alternators would put the engines under load to promote rapid warm-up and the electrical power was dumped into oil and water heaters (and on the diseasle Jags they had electric cabin heaters). I think the alternator fitted to the V6 diseasle was 100kW.
magnul
  • Trondheim, Norway
« Reply #19 on: 05 February 2009, 17:57:41 »
Can you give a ball park estimate of the extra energy consumption and relate that energy consumption to the benefits of having cleaner air in a city centre? My second car (a mazda 323) doesn't have a secondary air system, and it's a huge difference between the two cars how fast the cats starts working.
Martin_1962
« Reply #20 on: 05 February 2009, 20:05:35 »
My 2.6 doesn't have SAI, I think that says a lot
magnul
  • Trondheim, Norway
« Reply #21 on: 05 February 2009, 21:25:20 »
It says that the SAI's function has been replaced by something else. There's a big difference between replacing and removing.
Martin_1962
« Reply #22 on: 05 February 2009, 21:35:48 »
Nope any effect it had is now managed by the ECU
magnul
  • Trondheim, Norway
« Reply #23 on: 05 February 2009, 21:50:38 »
That's exactly what I meant. So when removing it from a car that had it fitted, the effect is gone->higher emissions.
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #24 on: 06 February 2009, 06:42:33 »
Our government put the price of fuel up so high that none of us could afford to drive!!!  Less emissions  ;)
Wwll done Mr Brown :-X
