Author Topic: head gasket gone  (Read 2895 times)
Re: head gasket gone
« Reply #15 on: 09 February 2009, 09:22:14 »
So they skimmed about 0.25 mm off.
Yes, there is a what is considered to be a thou in metric (mm's!)
Quite clearly the head was not warped if that is the case so no point machining it at all really!
ah! I can imagine amount better know... ...can't work in these odd units that fogies use :y
« Reply #16 on: 09 February 2009, 09:26:10 »
Exactly!
« Reply #17 on: 09 February 2009, 09:33:32 »
But not what you'd generally use in a workshop. As 0.010"/10 thou is aprox 0.25mm (1mm ~0.040") for everyday use, hundredths of millimeters is plenty small enough. Thousandths of mms equates more to '10ths of thous of an inch'
« Reply #18 on: 09 February 2009, 09:45:23 »
We work in real thou (mm's).....but then we work with fibre optics and silicon!
« Reply #19 on: 09 February 2009, 09:47:58 »
 ...... and you won't be skimming them in a Brigeport/etc in a machine shop!  :y  :y
