Author Topic: Nearside rear squeaking  (Read 1825 times)
V6 Gix
  • Wallingford
« on: 10 February 2009, 16:01:13 »
Went over quite a large pothole which made a very nice THUMP.
Now the nearside rear is squeaking really badly. Getting in and out of the car...squeak....getting in....squeak.
A liberal coating of WD40 has helped, but has that pothole damaged something?
The MOT is due soon, and I'm dreading it. :(
I hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me
neilr
  • Barnet, Herts
Re: Nearside rear squeaking
« Reply #1 on: 10 February 2009, 18:13:10 »
youll probably find the spring has snapped at the bottom!
Dazzler
  • Haverhill, Suffolk
« Reply #2 on: 10 February 2009, 18:14:27 »
Have you checked to see if you have a broken spring??
V6 Gix
  • Wallingford
« Reply #3 on: 10 February 2009, 18:15:54 »
Can't get under the car and I don't have a jack.
Broken spring? Arse. >:(
How much is that gonna f*ckin cost. :(
Dazzler
« Reply #4 on: 10 February 2009, 18:18:08 »
If it has broken then about £40 each and should be changed as a pair.
V6 Gix
  • Wallingford
« Reply #5 on: 10 February 2009, 18:28:43 »
£40 each?
If that is all that needs doing then I'll be a happy camper.
Cheers Dazzler. :)
« Reply #6 on: 10 February 2009, 18:54:49 »
Must confess, I've actually paid £105 for a pair of rear springs (suspension parts should be replaced in pairs :y :y) from a local factors as they are good quality instead of the cheapo ebay ones :y :y
But easy enough job to do :y :y
« Reply #7 on: 10 February 2009, 21:07:34 »
KYB springs are about the best aftermarket ones you can get and are no more than 40 quid each
V6 Gix
  • Wallingford
« Reply #8 on: 10 February 2009, 21:37:22 »
Brilliant. Many thanks for the info guys, really appreciated.
V6 Gix
  • Wallingford
« Reply #9 on: 10 February 2009, 21:42:45 »
On another note, is the Mig safe to drive with a broken spring?
