Author Topic: Broken rear coil spring replacement  (Read 910 times)
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« on: 10 February 2009, 15:34:39 »
1999 (R) Omega Elite V6 Auto.
ARRRRRRGH! It has let me down and failed the test on a broken rear coil spring. Could'nt just be light bulb could it?
What is the best way, and easiest to change a rear coil spring?
I have found a replacement but think that they should maybe be changed in pairs?
The haynes manual seems to be making a mountain out of a molehill so someone please help!
Regards
Ray
Re: Broken rear coil spring replacement
« Reply #1 on: 10 February 2009, 15:36:21 »
« Last Edit: 10 February 2009, 15:36:56 by RobG »
Martin_1962
« Reply #2 on: 10 February 2009, 22:53:53 »
Wheels off
Shocks unbolted
Axle stands under rear end sills
Jack under diff
Drop it down slowly, fit new springs - you may need to remove brake pipes - I didn't
Martin_1962
« Reply #3 on: 10 February 2009, 22:54:29 »
Wheels off
Shocks unbolted
Jack under diff
4 bolts hold the diff up
Page created in 0.046 seconds with 20 queries.
