Author Topic: Auxiliary belt  (Read 3753 times)
largecol
  • Middlesbrough
  • I cant see my socks!!
Re: Auxiliary belt
« Reply #15 on: 11 February 2009, 23:11:24 »
He he... yes mate belt is fitted fine - since last message had a mobile autospark test the leccy system and guess what? he said that the alternator is shagged!!! how come this wasnt picked up when it was bench tested now i`ll have to do half the job all over again, is there a garage bloody any bloody where that can be trusted/believed/relied on any bloody where???? not to mention the hundred -odd quid for a recon. ggrrr  >:( >:( >:(
Pssssst! The man in my avatar aint really me!!
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: Auxiliary belt
« Reply #16 on: 12 February 2009, 14:59:46 »
Are you sure the earth leads haven't been disturbed/disconnected?
As a final check, (as you can't trust any tinker!), try securely clamping a jump lead from anywhere convenient on the engine block to the negative post on the battery.
Start the engine and see what happens.
If the light goes out - voila - you've got duff earthing.
If the light stays on, well, open your wallet ...... !
