Author Topic: projector height adjustment  (Read 3694 times)
VX1
  • Reading, Berkshire
Re: projector height adjustment
« Reply #15 on: 17 February 2009, 19:31:03 »
i can alter the height from inside the car ok
and when i put it back to 0 and check the beam height it stil looks like it has not moved
Nick you have to turn them quite a lot until you see any difference, just keep turning them until it has reached the diesired height, if this still dosen't work then you will need to remove the lens to reconnect the clips inside that holds the reflector on.
Mark do you mean the one nearest the grill or wing?
Paul  :y
Vx Trade club card holder
Halfords trade card holder
nick v6
  • walsall / west midlands
« Reply #16 on: 17 February 2009, 19:32:52 »
Paul  :y
i turned it loads
so i will remove the lense in the morning and do the clip
thanks for the help :y
nick v6
« Reply #17 on: 17 February 2009, 19:34:09 »
nice one
ill do it tomorrow now
going a bit to dark now
thanks again
ill let you know how i get on
best time to do it whens its dark  :y
 ;D ;D ;D
for cough's and cold's take bechams
 ;D ;D ;D ;D ;D ;D
VX1
« Reply #18 on: 17 February 2009, 19:37:20 »
I had the same problem with my nearside headlight so I removed the lens replaced the adjusters put it all back refitted the headlight went to turn to adjust and then crack!!!!!!!!! the inside wont adjust now so bought a new one from work for £75 all in.
Paul  :y
stuart30
« Reply #19 on: 17 February 2009, 21:35:04 »
Probably no help nick but if you use after market bulbs it can throw off the wrong beam...my passenger side light was literally pointing over at the drivers side light.
MOT mate tried too adjust but made no difference....popped the standard bulbs back in and hey presto.
Might be worth taking a look at the bulbs.
nick v6
« Reply #20 on: 17 February 2009, 21:36:42 »
ill take a look in the morning and see what the problem is
MutantCav
  • Gainsborough
« Reply #21 on: 17 February 2009, 21:52:03 »
 ;D ;D ;D ;D
Recessed Allen key adjustment on the front of the lights...
Is that the front as you look at the car, or the back of the lights??
 ;D ;D ;D ;D
« Last Edit: 17 February 2009, 21:53:53 by ShieldOfSteel »
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #22 on: 18 February 2009, 13:13:32 »
it will take a LOT of turns to adjust the height (if the adjuster isn't snapped :-X) i used a hex drive bit in my cordless drill to set mine :y
nick v6
« Reply #23 on: 18 February 2009, 13:16:36 »
ive managed to get it down a bit
ill get it checked out later
ive noticed a lever that widens the beam a bit
what does is it meant to be for
« Reply #24 on: 18 February 2009, 13:20:19 »
Continental driving. Flattens beam :y
nick v6
« Reply #25 on: 18 February 2009, 13:21:32 »
so where do i have the lever
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #26 on: 21 February 2009, 06:12:30 »
Nick,
the lever is inside the bulb cover in the back of the lamp housing, it's illustrated in the owners manual quite well...  once you know where it is it's easy to flick over for UK or Continental driving...
Think theres a PDF of a manual on here somewhere if you haven't got one..
DC  :)
ed: Found it  ;)
http://www.omegaowners.com/forum/YaBB.pl?num=1232026150
« Last Edit: 21 February 2009, 06:21:20 by dave_c »
nick v6
« Reply #27 on: 21 February 2009, 07:07:26 »
Nick,
DC  :)
ed: Found it  ;)
got it
thanks
