Author Topic: How dose the adaptive GB work  (Read 3407 times)
Re: How dose the adaptive GB work
« Reply #15 on: 12 February 2009, 20:02:14 »
yes mate,its the law,if they dont get used they get stuck in the same position ,which wastes petrol which in turn makes polar bears sad.
you can tell this to your mrs from me,chairman of greenpeace international. :y
« Reply #16 on: 12 February 2009, 20:03:47 »
Which is my excuse, because after the slow miles she's nursed it, being the sane and sensible driver we all aspire to be, when I do get to use it it's playtime a requirement that the car (once suitable warm) gets a "excerise" towards the higher end of the range.
I'm sure I remember being told that I should test the multirams properly from time to time.
Exercising them will stop them sticking ::)
Matchless
  • Nottingham
    • A white van
« Reply #17 on: 12 February 2009, 20:42:44 »
How does the adaptive gear box work on these .
Thanks
Steve.   :y
It takes account of road speed, throttle position, rate of change of throttle, engine and gearbox temperature, external temperature, level of grip available, presence (or not) of a passenger and then works out the ideal gear ratio, all in 3 milli-seconds.
It then engages a completely different one.
« Reply #18 on: 12 February 2009, 20:51:48 »
Thanks
Steve.   :y
Better than the wife in her clit then .. takes her 3 full seconds to exactly the same !!!
« Reply #19 on: 19 February 2009, 17:50:24 »
I emailed Vauxhall to ask. They replied today with :-
Dear Andy B
Thank you for your email dated 12 February 2009.
I can confirm, following receipt of your email, I contacted our Technical Department.  They advised that, unfortunately Vauxhall Omega vehicles do not have an adaptable gearbox.
Once again I thank you for contacting us and for allowing me to comment.
Yours sincerely
Becky Lancaster
Customer Care Manager
Quite whether that is an answer to my question of - do any Omegas have adaptive gearboxes I'm still not sure  :-/  ;D  ;D  ;D
webby23
  • Nottingham
  • MV6
« Reply #20 on: 19 February 2009, 18:05:51 »
I know its only words, but isnt ADAPTIVE different to ADAPTABLE ??
Maybe she didnt understand the question.......?
I have never known Mark DTM to be wrong about anything to do with Omegas, whatever the topic.....Not that I would know if he is right or wrong cos I know jack shi...........!!
« Reply #21 on: 19 February 2009, 18:08:50 »
I know, I hvave my doubt as to whether she's asked tech dept the right question.  :-?  ;)
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #22 on: 19 February 2009, 18:50:22 »
I'm sure I read in the owners hand book that when towing the gearbox would adapt to reduce the amount of shift downs that would be caused by the extra load on the engine. :-/
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #23 on: 19 February 2009, 20:04:36 »
Actually they are very adaptable & will even work in a BMW! :D
« Reply #24 on: 19 February 2009, 20:26:09 »
Tony H
  • liverpool
« Reply #25 on: 21 February 2009, 13:43:54 »
