Pages: 1 [2] 3 4 5 6 7 8 9   Go Down
Author Topic: LPG kit bulk buy & / or install party  (Read 19071 times)
Craig_R
  • Watford
Re: LPG kit bulk buy & / or install party
« Reply #15 on: 02 November 2007, 17:20:31 »
Spare Wheel tanks are no good for saloon omegas as you cant get to the rear light cluster on that side its ok for estates like TD has as it gos on the rear floor
Mod's
[To be Fitted]Reverse Sensors
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #16 on: 02 November 2007, 17:24:54 »
the filler does have to be exterior mounted, however it can be colour coded if that would help hide it.
one other thing to point out, all the feedback I have have about vertical tanks is that they do give issues, are expensive and suppliers can be few and far between
Ken T
  • Stockport
« Reply #17 on: 03 November 2007, 01:59:54 »
I think you can just get to the rear cluster mounting nuts, and so if you need to replace the bulb, you could remove the whole assy and get to it that way. I think Sassenach had a tank in the spare tyre well, and how often do you need to change these bulbs?. If it causes a bit of agro every 3 years, its not a lot of trouble, and if the tank were connected with a flexible pipe, then the whole tank could be removed if there was a problem. Flexible unbraided pipes are used for connecting up Gas welding tanks, and Accetylene is a lot more dangerous than LPG.
Ken
Ken T
  • Stockport
« Reply #18 on: 03 November 2007, 02:14:13 »
I am interested, as I have most of the bits to do it, but always seem to run out of time !. I got an OMVL 21C system, and one of these multi system programming kits.
OK, here's the data:
Ken Termie
Gomersal (can travel !)
2.2L auto.
need a programming dongle.
Need pipes (both dia's), pipe connectors, rear filler, and poss tank.
Vert Toroid. I use my boot a lot, so couldn't give up the space for a cylinder.
party, yes please !
I thought the LPG guidance notes said that a pipe within 10" of the exhaust needed heat shielding. So you stick a piece of something between the tank and pipe. Mind you in this situation the tank will prob be closer than 10" to the exhaust, and there is only a piece of  tin between them.
Would it not be poss to use a hor toroid vertically, if you modified the filler cutoff to give the 80% when in that orientation. Might be as simple as rotating the filler/cutoff assy through 90deg. Would cost a lot less.
Ken
« Reply #19 on: 03 November 2007, 18:08:01 »
Well, that's 8 of us interested, including JamesV6CDX who I know is up for it.
The supplier can get hold of 4 different sizes of vertical toroidal tank, so there's plenty of scope for finding the best fit, although working out how to route the pipes needs some thought. Whilst this won't give fantastic range on LPG I work a mile from an LPG garage so a regular fillup won't be too bad. I've lived with a Westfield that only does 165 to the tank for 7 years and it's not too much of a hardship.
One idea I had for the light cluster issue is that you can get replacement LED bulbs to fit in the socket of a normal filament bulb. These should, in theory, have a much longer life than filament bulbs so may be worth considering. They'll probably need some load resistors adding to keep the flasher unit / MID bulb failure sensing happy.
Anyway, looking good.
Any more interested?
sassanach
  • trowbridge
« Reply #20 on: 03 November 2007, 20:31:03 »
i had the largest tank you can get in the spare wheel well with an actual capacity of 41 litres(ive since fitted a 100 litre tank across the rear seats)i routed the pipe around the rear of the car behind the bumper to avoid the exhaust altogether.as a ps you can now get flexible plastic lpg pipe instead of copper,makes it a lot easier to route the pipe to the front.
Martin_1962
« Reply #21 on: 03 November 2007, 20:32:44 »
I think it is easier to route up the right hand side
x25xe
  • Hayes, Middlesex
  • Avater removed due to size
« Reply #22 on: 05 November 2007, 09:48:18 »
Kevin,
Can the supplier supply the cylinder type tanks?  I am not too concerned about boot space and range on LPG is more important to me as no stations near me stock LPG :(
Your idea about the LED replacement bulbs is a good one although, as you say, a series resistor will no doubt be required.
I am defiantly up for this and look forward more information.
x25xe
  • Hayes, Middlesex
« Reply #23 on: 05 November 2007, 09:50:09 »
I am guessing that the 100 litre tank fits behind the rear seats in the boot?  Is the 100 litre capacity the total or usable capacity?
« Reply #24 on: 05 November 2007, 09:53:16 »
IIRC you lose a percentage I think 20% but im sure someone will confirm :y
« Reply #25 on: 05 November 2007, 09:57:49 »
Thanks for the info. I was thinking across the back was probably going to be the best option for routing the pipe.
Sounds like range is going to be very limited with a toroidal tank. Cylinder tanks are also available no problem. I will find out what tanks he supplies and see if I can dig up a list of dimensions.
Craig_R
  • Watford
« Reply #26 on: 05 November 2007, 09:58:49 »
Yep Elite Pete is right you cant get a 100 litres in a 100 litre tank
I have a 75 litre tank and it holds roughly 60 litres it does depend on when i fill it also.
If you fill it on a really cold night you can get a little more in, But if you dont drives it far and its a warm day next day the tank will Vent some of your gas as a safety feature
Mod's
Paulus
  • Wheaton Aston
  • Are you lookin' at me??? Punk???
« Reply #27 on: 05 November 2007, 12:56:15 »
COUNT ME IN!!!!!
I want to do mine myself - no point in paying people for things you can do yourself.
Paul Fielding...
Staffs.
3.0
Yes.
Yes.
Cylinder.
Most defo!!!!
next....
Growing old disgracefully...
« Reply #28 on: 05 November 2007, 13:03:42 »
I want to do mine but until I find out why it isn't running right theres no point :(
« Reply #29 on: 05 November 2007, 18:36:05 »
Yup, as Kev knows, I'm definately up for gassing my car - time permitting!!
Pages: 1 [2] 3 4 5 6 7 8 9   Go Up
