Author Topic: selector switch  (Read 1835 times)
laurie
  • headley down, hampshire
selector switch
« on: 03 March 2009, 10:34:03 »
Hi
Can anyone point me to the selcector switch link to clean and remove it?
thx
Re: selector switch
« Reply #1 on: 03 March 2009, 11:49:20 »
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: selector switch
« Reply #2 on: 03 March 2009, 13:43:18 »
But do not use WD 40 to clean it!
Pop into Maplin Basingstoke & get a can of switch cleaner
They are next door to Halfords
Varche
  • middle of Andalucia
    • Golf Estate
Re: selector switch
« Reply #3 on: 03 March 2009, 14:21:48 »
And don't forget to adjust it using the 2mm drill as per haynes manual when you refix it. It makes the world of difference.
varche
laurie
Re: selector switch
« Reply #4 on: 03 March 2009, 15:24:47 »
ok, i have noticed that when depressig the brake or releasing it i used to get a click from the gear selector as normal. However i have noticed this no longer happens, does this point to the selector switch at fault?
Re: selector switch
« Reply #5 on: 03 March 2009, 19:31:40 »
ok, i have noticed that when depressig the brake or releasing it i used to get a click from the gear selector as normal. However i have noticed this no longer happens, does this point to the selector switch at fault?[/quote]
In a word, No. More than likely the brake switch up behind the pedal playing up. :y
laurie
Re: selector switch
« Reply #6 on: 04 March 2009, 09:04:52 »
Hi
Can you tell mw where this is and how to test or how to get a replacement etc.
Page created in 0.026 seconds with 20 queries.
