Author Topic: Are all Omega Windscreens the same?  (Read 2125 times)
MutantCav
  • Gainsborough
« on: 05 March 2009, 19:30:59 »
Is the pre facelift and facelift windscreen the same??  :)
Re: Are all Omega Windscreens the same?
« Reply #1 on: 05 March 2009, 19:43:26 »
not sure but I must warn you even for the same model the qualities are different..so check from sideways before buying..
    • 530D M Sport, 330i Coupe
« Reply #2 on: 05 March 2009, 19:43:34 »
Some are, some aren't
Believe the differences are facelifts with rain sensitive wipers and some of the very last facelifts had heat reflective screens though I have never seen one in the flesh.
Also not siure if some screens don't have the top shadeband
« Reply #3 on: 05 March 2009, 20:00:14 »
The EPC lists 9 windscreens ...  :(
  1  WINDSCREEN, LAMINATED, CLEAR (IDENT GL)   -X1999999 90457720 1 61 031 1
  1  WINDSCREEN, LAMINATED, TINTED (IDENT GM) (EXC.HEAT REFLECTIVE WINDSCREEN) (EXCEPT RAIN SENSOR)    90457721 1 61 030 1
  1  WINDSCREEN, LAMINATED, HEAT REFLECTIVE (EXCEPT RAIN SENSOR) (IDENT HG)    9146283 1 61 056 1
  1  WINDSCREEN, LAMINATED, HEAT REFLECTIVE (FOR RAIN SENSOR) (IDENT NQ)    24433002 1 61 077 1
  1  WINDSCREEN, LAMINATED (IDENT NP) (FOR RAIN SENSOR) (EXC.HEAT REFLECTIVE WINDSCREEN)    24433003 1 61 078 1
  1  WINDSCREEN, LAMINATED, HEAT ABSORBING, HEAT REFLECTIVE (IDENT SC) (EXCEPT RAIN SENSOR) (NOT USED)      1
  1  WINDSCREEN, LAMINATED, HEAT ABSORBING, HEAT REFLECTIVE (IDENT SD) (FOR RAIN SENSOR) (NOT USED)      1
  1  WINDSCREEN, LAMINATED, HEAT ABSORBING (IDENT SE) (FOR RAIN SENSOR) (EXC.HEAT REFLECTIVE WINDSCREEN) (NOT USED)      1
  1  WINDSCREEN, LAMINATED, HEAT ABSORBING (IDENT SF) (EXC.HEAT REFLECTIVE WINDSCREEN) (EXCEPT RAIN SENSOR) (NOT USED)
leevaux
  • West Sussex
« Reply #4 on: 05 March 2009, 20:00:46 »
A friend of mine has just replaced his on his 53 plate elite est and has had trouble finding the right one his has rain sensitive wipers and they have a bracket glued to the screen his cost him £261 they also do a heat reflective screen this is about £450 and a standard screen with top tint for about £100  all fitted the only thing i forgot was ware he got it from!!!!!!!!!! :-[ i will find out.
« Reply #5 on: 05 March 2009, 20:06:02 »
If you fit a heat reflective screen where on wasn't previously fitted I believe you will need to get the solar sensor sensitivity / climate panel adjusted to compensate.
MutantCav
  • Gainsborough
« Reply #6 on: 05 March 2009, 20:06:06 »
Ok I'll change the question as I didnt think it was so complicated lol
Will the windscreen from a 2000 V reg facelift saloon fit a 98 R reg estate do you think?
« Reply #7 on: 05 March 2009, 20:07:41 »
Well they will all fit as they are all the same size etc.
« Reply #8 on: 05 March 2009, 20:12:44 »
Looking at the EPC, the diagrams show both the saloon & estates as having the same windscreens, and the "range" is up to -X1999999, and no other range/breakpoint is specified .....
So if I had to guess I'd say it would fit .... but maybe someone who knows the EPC better than I would give a more conclusive answer.
HTH
« Reply #9 on: 05 March 2009, 20:15:00 »
HTH
Physically any Omega screen will fit any Omega as the body shell never changed only bumpers and trim and various bolt on panels between prefacelift and facelift.
Page created in 0.032 seconds with 20 queries.
