Author Topic: Facelift Omega - Rubbish heater?  (Read 3856 times)
murse
  • UK
  • Stressed
« on: 04 March 2009, 23:48:13 »
My previous (non-climate and smaller engined) migs still had decent heating iirc.  The current one takes forever to heat up (as in just warm after 12 mile commute) and never gets that warm.  Any suggestions if this is normal on these or do I have a problem?  Aircon blows nice and frosty  :(
More miles than the starship Enterprise but she keeps on rolling!  (Edit: not in a straight line anymore!)
Re: Facelift Omega - Rubbish heater?
« Reply #1 on: 04 March 2009, 23:49:48 »
What does the temp gauge sit at :question
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #2 on: 05 March 2009, 00:54:33 »
Does it mist up easily, too?
Robmetaxa
  • Southampton
« Reply #3 on: 05 March 2009, 08:04:33 »
My Facelift Mig is pretty good, gets hot in a few minutes, but the blower stays off until the engine has warmed a tad then starts to blow, so as not to blow freezing cold on the windows, all in all a very good system, think you may have a little problem.
Rob
kevpuk
  • Poole
« Reply #4 on: 05 March 2009, 09:55:57 »
Thermostat issue ?
Markjay
  • London
« Reply #5 on: 05 March 2009, 11:11:19 »
Had a facelift for 6 years, and while I always thought the Climate had a mind of it's own and I never quite figured it out, the one thing that was working well was the heating... after all the car was built by Germans for Germans in... err... Germany. And it's cold there. So in short I don't know what the problem is, but it is not one of those 'they are all like that' things....
Alas, no more Omegas....
richardirv
  • Leeds, West Yorkshire
    • Omega 2.6 MV6 2002
« Reply #6 on: 05 March 2009, 13:17:44 »
Rob
I agree with this!! mine is exactly the same!
Tawfield
  • Berkshire
« Reply #7 on: 05 March 2009, 16:30:25 »
No probs with my Elite set temp leave on auto /eco,looks after its self. :y
Big_Roger
  • Southampton
« Reply #8 on: 05 March 2009, 16:46:57 »
Hi,
Sounds like you have a problem, heater on mine is very efficient. Will bring interior of car up to 22 deg C from outside temp minus 10 dg C in 5 mins from cold start.
Coldest I have so far experienced was minus 12 deg C outside, but in car was as warm as toast at 24 deg C.
I would start checking out operation of engine thermostat and HBV valve, and flap operation on heater unit.
Regards
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
Iain
« Reply #9 on: 05 March 2009, 21:01:36 »
Mine is red hot roasting at 28c!!! ;) :y
Heats up pretty quick,same as above,wont blow til there is some heat in the system.....
You could try using the recirculating button,that will heat up the cabin a tad quicker....
I would say as an average from overnight cold it takes about 5-7 mins to get heat....
topcat
  • Doncaster
« Reply #10 on: 05 March 2009, 21:41:50 »
Thermostat could be stuck open other wise maybe matrix
murse
  • UK
  • Stressed
« Reply #11 on: 05 March 2009, 23:05:01 »
Thanks for all the replies & advice - will get investigating  :y
Edit:
Very rarely more than first notch - blower works from cold too?
« Last Edit: 05 March 2009, 23:08:42 by murse »
Iain
« Reply #12 on: 05 March 2009, 23:13:12 »
A thermostat stuck open me thinks.....constant cooling! not good,car will never heat up if this is the case,will effect your economy and all sorts,thats how it takes ages to heat..(because it isn't!)
Temp gauge should sit half way on the dial... :y
murse
  • UK
  • Stressed
« Reply #13 on: 05 March 2009, 23:19:47 »
Sounds like a plan - by the way anyone know the best place to get a facelift haynes manual?
Iain
« Reply #14 on: 05 March 2009, 23:21:31 »
Cant get them mate,Haynes said the facelift was not sold in enough numbers to produce a book
Page created in 0.023 seconds with 20 queries.
