Author Topic: A DEAD Windscreen Washer Pump or is it?  (Read 3447 times)
Richie London
  • heathrow
Re: A DEAD Windscreen Washer Pump or is it?
« Reply #15 on: 07 February 2009, 14:38:18 »
Can this be done without taking the bumper off?  Me fears not 'cause I can't seem to access it even having removed the grill.
Quick question.  Are the pumps on the same fuse as the headlamp washers?
Greg
is yours not the same as mine,mines a 98 2.5. i took the connector off. the one on the left in the pic, then just pulled the pump out, bit stiff but quite easy, the grommet is in the hole.
Greg2041
  • Frinton-on-Sea
« Reply #16 on: 07 February 2009, 15:12:54 »
I've got a huge air intake pipe in the way (I'm guessing that's what it is), so I can't reach the pump.  Mine's a '98 3.0 litre so I suppose it could be different to the 2.5.
Any ideas how I can remove this big pipe to access the washer pump?
Many thanks
Greg
« Last Edit: 07 February 2009, 16:43:25 by Greg2041 »
« Reply #17 on: 07 February 2009, 17:03:40 »
Many thanks
Greg
Torx headed self tapper towards the top, I can just see mine with the grille still in place, then pull it off. It's just a push fit into the next bit of ducting back.
Greg2041
  • Frinton-on-Sea
« Reply #18 on: 07 February 2009, 17:32:37 »
Thanks.  I will try tomorrow in the light.  Couldn't quite see where the ducting join was though or if it went into the wing?  So once the screw is out, should I just give it a tug and see?
« Reply #19 on: 07 February 2009, 17:34:46 »
I thinks so, I think I might have even just moved it up out of the way.
Greg2041
  • Frinton-on-Sea
« Reply #20 on: 07 February 2009, 18:04:05 »
Did try moving it out of the way but its made of quite a rigid plastic.
« Reply #21 on: 07 February 2009, 20:53:49 »
There is a guide to removing pump in Maintence Guides section
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #22 on: 07 February 2009, 22:13:44 »
Brute force and ignorance work well with that pipe :y
Greg2041
  • Frinton-on-Sea
« Reply #23 on: 08 February 2009, 09:12:38 »
Help.  Had a look at the maintenance section but whilst I now know that the ducting is where the air intake starts, I still can't get to the back of it sufficiently to access the washer pump.
Any suggestions?
Greg
Ps Just seen the previous post so I will drag it out if need be.  Please do tell me if I shouldn't!
« Last Edit: 08 February 2009, 09:14:01 by Greg2041 »
« Reply #24 on: 08 February 2009, 10:08:03 »
Any suggestions?
Greg
I have never had to remove the intake pipe  :-/
Greg2041
  • Frinton-on-Sea
« Reply #25 on: 07 March 2009, 15:42:42 »
Took a while and a dodgy part bought off Ebay, supposedly genuine, it wasn't, but it's now working.  I managed to yank the air duct out of the way.  Bit of a fiddle and I couldn't have done it without you guys, so thank you.
Greg
BTW the problem was a seized washer pump!
Page created in 0.031 seconds with 20 queries.
