Author Topic: Rear Coil Springs - Where to buy?  (Read 6887 times)
Re: Rear Coil Springs - Where to buy?
« Reply #15 on: 06 March 2009, 21:58:49 »
mine had a creak. Esp over slopes or stear drive ways, or where one wheel was higher than the others, like mounting or dropping one a curb.
Then it failed the mot for rear donut bushes. Changed the bushes, no more creak. Only from drivers side iirc.
The bendy seat thing sounds cheaper and easier. Maybe try that first... what ever the plate is?
Iain
« Reply #16 on: 06 March 2009, 22:06:49 »
Not sure the description fits my noise but worth a shot....
So is this located under the seat cusion?
Iain
« Reply #17 on: 06 March 2009, 22:09:25 »
I think you said this when i mentioned it before Chris,did you put Senny donuts on it....?
« Reply #18 on: 06 March 2009, 22:40:26 »
As my scan says .. "remove rear seat ..."
Iain
« Reply #19 on: 06 March 2009, 22:44:18 »
Actually i meant the seat part or the backrest part
As in...... is it under the ar$e part or will i need to unbolt the backrest parts
« Reply #20 on: 06 March 2009, 22:45:39 »
Under the arse, just pull the two tags at the seat base and it lifts up.
Iain
« Reply #21 on: 06 March 2009, 22:53:50 »
Ta  :y
« Reply #22 on: 07 March 2009, 03:00:23 »
I did...
Iain
« Reply #23 on: 07 March 2009, 22:03:01 »
Better?
Where did you get the Senny ones? and how much? :y
« Last Edit: 07 March 2009, 22:03:54 by Iain »
