Pages: 1 [2] 3  All   Go Down
Author Topic: oh no! my damn car wont start, advice needed chaps  (Read 4939 times)
bluespurr
  • bristol
Re: oh no! my damn car wont start, advice needed chaps
« Reply #15 on: 01 March 2009, 18:25:03 »
hi i'm new to this but i'm wondering if the paperclip job will help me i have changed the rocker covers today and now it wont start i get a knocking noise from number 4 cylinder. The eml light doesn't flash and i don't really want to strip it back down again lol
b16 b3n
« Reply #16 on: 01 March 2009, 18:31:27 »
 :o a knocking noise? im intreeged. Let me know if youve found it, my mates got exactly th same problem and even i cant figure it out. Im striiping his back down tomorrow at work and see if hes done everything  correctly. :y
bluespurr
  • bristol
« Reply #17 on: 01 March 2009, 18:38:34 »
i'll let you know i think the only thing it can be is it could be the codes been lost in the ecu as i disconnected it. But i just cant work it out it wont even idle it just splutters and knocks and thats about it do you know if the ecu losses the codes?
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #18 on: 01 March 2009, 18:45:26 »
bluespurr - it's very bad etiquette jumping on the back of someone else post...mods/admins?
Wayne - sorry I can't help here as i'm not a V6 owner (yet...)
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
slb
  • elland
    • 99 2.5 v6 cdx
« Reply #19 on: 01 March 2009, 18:46:18 »
how many times have you tryed to start it again :question
bluespurr
  • bristol
« Reply #20 on: 01 March 2009, 19:01:07 »
quite a few but no luck, even tried bumping it
slb
  • elland
    • 99 2.5 v6 cdx
« Reply #21 on: 01 March 2009, 19:19:05 »
are the fuel pipes on ok and the injecters conected up at the back :question
Wayne
« Reply #22 on: 01 March 2009, 19:33:21 »
is this an answer to my question... or somebody elses?
« Reply #23 on: 01 March 2009, 20:21:09 »
Wayne - have you got fuel at the fuel rail?
Wayne
« Reply #24 on: 01 March 2009, 22:02:15 »
Hi mate
fuel at fuel rail?  dont know what that means, you know what im like, lol
Wayne
« Reply #25 on: 01 March 2009, 22:04:15 »
i take it that the error code 31 is the crank sensor, and it needs replacing then chaps?
« Reply #26 on: 01 March 2009, 22:08:12 »
31 on a non running engine is non conclusive.
Wayne
« Reply #27 on: 01 March 2009, 22:17:30 »
what does that mean mate?
it could be ANYTHING?
so i could be sat with a car that wont ever start again?
how much will that cost to fix, or is that a "how long is a piece of string question"
« Reply #28 on: 01 March 2009, 22:28:36 »
It could well be the crank sensor, but we can't prove it.  But then it could also be a number of other things, including fuel pump/relay etc
philhoward
  • Staffs
« Reply #29 on: 01 March 2009, 22:29:39 »
Start from the top, Wayne - an engine needs 3 things to run - compression, fuel and a spark.
If the engine sounds fine turning over, then thats one ticked off.
Next question - do you have fuel at the fuel rail (slacken the unions off gently and it should come squirting out).
Third - spark.  Test the old fashioned way for now (old spark plug against something metallic and see if you have a spark.
From the last 2 tests, it at least gives a clue where to look..
Pages: 1 [2] 3  All   Go Up
