Author Topic: x30xe Tuning...  (Read 9474 times)
miniator
  • Northern Ireland
    • My YouTube Channel
Re: x30xe Tuning...
« Reply #15 on: 13 March 2009, 11:01:27 »
surely a replacement panel filter is the same size as the old one and therefore able to draw more due to being less restrictive!?
i was thinkin an un-oiled one like a green cotton filter.
« Last Edit: 13 March 2009, 11:02:32 by miniator »
Omega Wanted: Facelift, 3.0/3.2, Elite/MV6, Charcoal Interior, W.H.Y.
Re: x30xe Tuning...
« Reply #16 on: 13 March 2009, 11:14:18 »
If you look at a stock air filter it is made from a VERY large piece of filter material which is formed into a concortina shape with fingers a good 30+mm deep. This results ina  massive surface area.
The foam ones are not even lcoe to this surface area!
Hence, keep the stock item and change it moreregulalrly than the 20K mile interval.
The only thing that will increase with a different type of fitetr is the intake noise  :y
Re: x30xe Tuning...
« Reply #17 on: 13 March 2009, 12:22:24 »
wow kevin, i think youve managed to contradict everything i have research thus far!
I didn't mean to be terse but it appears that the research you quote has been from tuning companies who are no doubt eager to sell you their products. You can't simply add up their power claims and conclude that you can get 300 BHP from a 3.0.
For one thing their claims might well be exaggerated.
Secondly, it's one thing to gain power from a standard engine but once an engine has had a certain amount of tuning it's a law of diminishing returns.
for a start, i know a 3.2 putting out 250 with just breathing mods. ie, a BMC CDA and a straight through exhaust system. so with the other mods ive mentioned youd have to agree that 280 would be possible?!
Where was that measured? A 30 BHP gain from some fairly rudimentary mods sounds too good to be true to me. Remember a lot of rolling roads (especially those owned by the guys who have just supplied you with tuning bits) tell the customer what he wants to hear.
Yes, 280BHP is possible. I have personally seen a naturally aspirated C20XE make 300 BHP and a natasp 1.8 Rover K series make 250 BHP on a rolling road that I trust to be accurate. However, both of those engines had been blueprinted and rebuilt with all steel internals.
Now, you might not have to be quite as extreme (by this I mean 9K RPM redline) with a 3.0 to reach that level due to the greater capacity but they will need substantial work to the heads, cams and bottom end. We're out of the realm of induction kits and sports cats at this level.
and that air filter comment, back that up with evidence please....a K&N for example will draw more air that the OEM paper one, and im talking panel filters here
Plenty of members have reported having "upgraded" their air filters using K&N panel filters, cone filters, etc. I can't recall one person who didn't admit it was only the noise that changed. The factory panel filter is huge for a 200 BHP engine (largely to support the long service intervals). The filter won't draw more air because the engine is already drawing all the air it can through the standard filter.
Do you have any more information on these at all Kevin?  I'm not registered on ABS, so can't see what the general crack is with these...
The thread is Here: http://www.autobahnstormers.org/forum/viewtopic.php?t=15007&postdays=0&postorder=asc&start=0
However, their forum is members only. The current situation is that a member has had a set of tubular manifolds for the V6 made up, and is asking if there's the potential to do a bulk buy. I will see if he is prepared to post the info. on here if it's of interest. IIRC, the prices being quoted were in the region of 600 quid, so not a cheap upgrade. :o
TECHNOPUG
  • Islington - London & Essex
Re: x30xe Tuning...
« Reply #18 on: 13 March 2009, 12:35:08 »
The intake isn't restrictive, so I wouldn't bother looking there for more horses. The Exhaust however, is an issue. You've improved things from the CAT back but it the CATS themselves and further forwards that are the real issue. Removing the CATS or fitting sports CATs will help. Manifolds and down pipes will still be limiting the flow so this is where good gains can be found.
       Biggest problem is that there are very few off the shelf goodies for the engine. A lot of improvements would need to be custom made. Inlelt and exhaust manifolds can be matched to the head, along with opening up the ports, bigger valves perhaps etc. Then you can take advantage of hotter cams. However, all this would need to be done by an experienced enginner - not a guy with a dremel. Seeing as there is so little demand for work on these engines, I doubt that you'll find someone who knows exactly what they are doing. It's as easy to lose power as it is to gain! You'd also need a live mapping session and quite probably a standalone ecu and software.
   As has been said, ultimately there isn't a great scope for tuning as the engines simply weren't designed to cope with much more power. The blocks aren't designed to allow sufficient cooling so would need to be radically engineered to ensure any sort of reliabilty. Rods and pistons would need to be replaced and probably crank too for 300bhp through forced induction. Engines have produced 300+bhp in race trim but they are very expensive, lots of custom work and not suited to street driving. To put it into perspective - an E36 M3 has the same power in stock tune!!  :o
  So...........spending cash on trying to extract more ponies from the X30XE is probably a fruitless task. By all means fit a better exhaust, that will help. But I'd concentrate on making sure that everything is in good condition and working properly as stock. If you want to spend money on going faster, then spend it on the brakes, tyres, coil-over suspension,  poly-bushes etc. Stripping the interior is free performance tuning don't forget! If it's really engine power that you want then I think looking into an engine swap is the way to go - Saab Turbo or even a SBC.
miniator
  • Northern Ireland
Re: x30xe Tuning...
« Reply #19 on: 13 March 2009, 12:57:42 »
well the guy making 250bhp on a 3.2, i know the rollers he run on and i have run 2 cars on them personally along with attending two rolling roads days and they are as accurate as you can get in NI, maybe the UK.
at easter im going to invest in a panel filter and make my own mantzel powerbox (replica) and run her again on the same rollers, just to see what kind of improvements i can get. i wouldnt mind having a look at those ABS mani's....expensive but what kind of gains is he getting?!
i would love to keep the 3.0 v6 as it makes a joyful noise and the torque is fantastic....i wouldnt mind a turbo (astra vxr) but how about something different like a vectra vxr engine? i query here is, what gearbox to use?!
« Last Edit: 13 March 2009, 12:58:44 by miniator »
TECHNOPUG
Re: x30xe Tuning...
« Reply #20 on: 13 March 2009, 13:13:03 »
Saab Turbo engines have same block pattern as GM engines that are fitted in Omegas - so they'll bolt straight onto existing miggy 'boxes. Easily make 300bhp with a few mods. Cheap and plentiful. Best bet for turbo power for sure.
miniator
  • Northern Ireland
Re: x30xe Tuning...
« Reply #21 on: 13 March 2009, 13:17:02 »
are they a 4 or 6 pot engine!?
what models were they fitted too?!
    • 530D M Sport, 330i Coupe
Re: x30xe Tuning...
« Reply #22 on: 13 March 2009, 13:32:30 »
Saab used the 3.0 in C form (transverse) so manifolds, downpipes etc aren't much use on a RWD car
Re: x30xe Tuning...
« Reply #23 on: 13 March 2009, 13:55:53 »
afaik, imho, tbh... save your money. Be patient and look for proven methods. In the mean time make sure the servicing is up to date, and the bushes are ok front and back. Service your ac, do the belts and filters. Etc.
 Then, hopefully, some answers will be ready. Ie where is the weakest link/restriction in the engine? From what i gather the exhaust manifolds are suspected to be most restrictive, hence the advice given by others perhaps. The stock items feed into a plenum rather than use the scavenging effect of a long downpipe which is also more expensive to make than the stock cast items. Why? Cost? Tuned for grunt and a flat torque curve? Is this at the expense of fuel economy for comfort? Or will free er flowing manifolds give better economy but a peaky tune, i cant beleive economy could get worse but thats probable if it flows more air. You get the general drift.
Once the above is known, then it may be worth further improvements, for instance there seems little point  fitting larger throttle bodies and bigger bore straight through exhaust if the manifolds tie a knot in the system in between.
You may get some gains here and there, but at what cost? More noise in the cabin? Worse economy? Loss of low down grunt where you need it most?
I find it amazing that a small tuning firm can turn over millions of pounds of r and d on what is an executive car, dont forget, with a panel filter, pipe and a chip without some down sides... Dont you?
The omega is not really designed with world touring cars in mind, and i beleive those that do race it bin the v6 for chevy v8! And a thing of beuty it is too.
Its your car mate, do as you please, personally i love a tinker, but it takes more than a tinker to beat what GM designed.
God im getting old. Nyear
TECHNOPUG
Re: x30xe Tuning...
« Reply #24 on: 13 March 2009, 14:00:34 »
Not the 3.0l ones - the 2.3 4 cylinders from the 9000's
Martin_1962
Re: x30xe Tuning...
« Reply #25 on: 13 March 2009, 14:48:49 »
3.2 has a steel crank
miniator
  • Northern Ireland
Re: x30xe Tuning...
« Reply #26 on: 13 March 2009, 16:20:46 »
thanks guys for all the info there, and i hear what your saying chris! i wont be doing anything more really to her (other than upkeep and driving her) til after the summer....as i have a second car itll probably be a little winter project. and hopefully by that stage the ABS mani's will be ready....fingers crossed!
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: x30xe Tuning...
« Reply #27 on: 13 March 2009, 23:43:56 »
Bin the V6 and install an LS2 thats what i would do or fit a C20XE redtop turbo the 3.2 is the engine to tune up not the 3.0
in the next few months i am looking to get a 02 3.2 V6 MV6 just waiting for the bloke to find a new car and i can buy his mint EX BT Facelift MV6 :y
then im going to investigate what happens when a 3.2 meets an Eaton ::)
markey mark
  • SLady bitshorpe north lincs
Re: x30xe Tuning...
« Reply #28 on: 13 March 2009, 23:47:12 »
you mean a c20let ! been thinking of supercharging mine £3500+ for a kit !  :o :o
good engine would be a vxr vectra 2.8 turbo  ::)
