Author Topic: wishbones  (Read 3420 times)
Re: wishbones
« Reply #15 on: 21 March 2009, 22:03:12 »
Angle the bottom ball joint out and lever the wishbone down as you feed the hub in.
I was worried about levering the wishbone down and damaging the new bushes as it doesn't drop down as low as the old one.
Lol, what do you think happens to them every time you jack it up  :y
Plus the front one is free to rotate as its not tightened  :y
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: wishbones
« Reply #16 on: 21 March 2009, 22:05:26 »
:-[ :-[ Thanks Mark, should go better tomorrow knowing that :y
« Last Edit: 21 March 2009, 22:06:01 by alexandjen »
Trade club card holder
Code scanner available
mick-1975
  • nottingham
Re: up date on wishbones
« Reply #17 on: 22 March 2009, 17:10:15 »
  just to let you know done wishbones and drop links today
 your right there right swines to do ,  :y
 as for the water leak , i found a hose that had came off the one underneath the inlet manifold , had to strip it back down and replace .
and in the mean time smashed my knuckles on the floor levering the wishbones down for the bottom ball joint ,, >:(
 all in all a job well done  and losts of kirsing  :y
alexandjen
  • The Silver Surfer
« Reply #18 on: 22 March 2009, 18:26:16 »
Good man  :y
Finished mine today, along with droplinks, front discs and pads.
Quick question - I pushed the piston in to expel the fluid within the caliper - will I need to bleed the front brakes as the pedel travel is somewhat excessive?  :-/
mick-1975
  • nottingham
Re: wishbones
« Reply #19 on: 22 March 2009, 18:29:53 »
yes mate , you will have to bleed them if you removed the calliper for easier access as mine kept falling round while fitting them wish bones !! :y
 when you pushed the piston back , did u unscrew the cap to the brake fluid resevoir!           :y
« Last Edit: 22 March 2009, 18:31:53 by mick-1975 »
alexandjen
  • The Silver Surfer
Re: wishbones
« Reply #20 on: 22 March 2009, 18:32:52 »
I removed the caliper from the carrier but did not remove the pipe.
I undid the bleed nipples to expel the fluid within the calipers, would this introduce air into the system?
mick-1975
  • nottingham
Re: wishbones
« Reply #21 on: 22 March 2009, 18:42:15 »
good ???  shoulnt of done , did u crip the flexi pipe ??
HerefordElite
  • Hereford
  • Welcome to the Shire
Re: wishbones
« Reply #22 on: 22 March 2009, 18:50:58 »
I undid the bleed nipples to expel the fluid within the calipers, would this introduce air into the system?[/quote]
In a word YES ::)
best way to allow the calliper to be pushed back is to take the top off the brake fluid reservoir but watch it doesn't overflow ;)
« Last Edit: 22 March 2009, 18:51:41 by herefordelite »
HerefordElite
  • Hereford
Re: wishbones
« Reply #23 on: 22 March 2009, 18:58:51 »
ps your brakes will need bleeding now:
http://www.carbasics.co.uk/how_to_bleed_car_brakes.htm
mick-1975
  • nottingham
« Reply #24 on: 22 March 2009, 19:00:04 »
Good man  :y
you shall have to bleed the whole system now as the brake pedal been pressed, :y
alexandjen
  • The Silver Surfer
Re: wishbones
« Reply #25 on: 22 March 2009, 19:05:49 »
Thanks all, didn't crimp the flexi pipe
I'll bleed the whole system next weekend with a pressure bleed kit, mig won't get used during the week :y
« Last Edit: 22 March 2009, 19:06:12 by alexandjen »
mick-1975
  • nottingham
Re: wishbones
« Reply #26 on: 22 March 2009, 19:07:11 »
  better to be safe than sorry  :y
alexandjen
  • The Silver Surfer
Re: wishbones
« Reply #27 on: 22 March 2009, 19:11:20 »
Yeh too right, I'll change the fluid again while I'm at it, only did it last year ::)
Know what you mean about smashing your knuckles - I smashed the end of my right index finger when the ratchet slipped and the back of my right hand looks as if a dog has mauled it ;D
Drives a lot straighter though, needs the WIM treatment now :y
mick-1975
  • nottingham
Re: wishbones
« Reply #28 on: 22 March 2009, 19:16:15 »
    mine to i think but not been out in mine yet as i have another one im using ,  going to be selling one soon ,
