Author Topic: Re: had enough  (Read 3670 times)
Omegatoy
  • UK
Re: had enough
« Reply #15 on: 26 March 2009, 20:08:25 »
sorry guys but that sounds like a gearbox fault to me!! i.e. autobox very low on fluid, or the dreaded ar 25 dying syndrome!! nothng to do with the engine!!  :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: had enough
« Reply #16 on: 26 March 2009, 20:10:13 »
If gearbox fluid is low then you will get this sort of effect...it takes loads of revving a while before it will shift then accelerates quite slowly...top up the fluid and it will be like a different gearbox if thats the problem...probably just 1 litre needed, but if really bad then 2 litres but follow the procedure to top up the fluid and jobs a goodun...again alf will be able to help you if needed :y
Agree, I thought and mentioned that earlier.
I think this is a Chicken and Egg one, (Engine / Gearbox).
Reckon I'd probally wait for the Maf sensor to arrive.
richy08
  • sheffield
Re: had enough
« Reply #17 on: 26 March 2009, 20:10:37 »
il top up the oil tomorrow and see wot happens it might work hopefully thanks alot guys a great help :y :y :y
