Author Topic: Bad Vibrations  (Read 3436 times)
portomega
  • Port Talbot, S. Wales
Re: Bad Vibrations
« Reply #15 on: 28 March 2009, 20:28:10 »
i would say that the wheel shakes, large slow vibrations
Cameron
  • Morayshire
Re: Bad Vibrations
« Reply #16 on: 28 March 2009, 20:52:43 »
Hmm, sounds more like bushes then...
Welung666
Re: Bad Vibrations
« Reply #17 on: 28 March 2009, 21:02:10 »
Does the vibration reduce as your speed does?
Re: Bad Vibrations
« Reply #18 on: 28 March 2009, 21:07:23 »
for me with discs if i brakes heavy ish at say 70, it would be smooth until 60 then wobble down though to 50, then smooth out again.
If its all the time its more likey to be bushes / wishbones i would say  :-/
portomega
Re: Bad Vibrations
« Reply #19 on: 28 March 2009, 21:22:58 »
its not at all times when braking its more when going from say 60 down to 40-30, below 30 or just normal braking it doesnt do it
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: Bad Vibrations
« Reply #20 on: 28 March 2009, 22:06:21 »
It could indeed be wear in any of the bushes/joints, but I'd still be inclined to go for the discs, given the symptoms described here.
« Last Edit: 28 March 2009, 22:07:09 by Reliance505 »
