Author Topic: again, no hot air?  (Read 4148 times)
kingplym
  • camden, hatfield, st.neots
  • sports on, kick down
Re: again, no hot air?
« Reply #15 on: 30 March 2009, 12:53:24 »
reply for robg those are the pipes that have been cut on mine and had a pipe put between?
i am willing to trade my electrical labour for parts work etc
« Reply #16 on: 30 March 2009, 13:11:15 »
As Cybertrucker says. It may well be that the heater matrix is leaking hence the bodged bypass. Only way to confirm that is hose water through one of the bulkhead connectors and see if it comes into the cabin :(
kingplym
« Reply #17 on: 30 March 2009, 13:14:30 »
wont that mess with me electrics?
« Reply #18 on: 30 March 2009, 13:39:32 »
Four options. 1) Instead of hose (bit drastic in your scenario) flexi funnel in bulkhead connector and jug of water, if matrix is leaking should only wet your footwell area. 2) could possibly be O ring seals where the pipes connect to matrix (still a PITA). 3) Matrix is breaked (another PITA). 4) Do without heat :(
kingplym
« Reply #19 on: 30 March 2009, 13:47:29 »
well it is nearly summer time? i just wont drive at night, cold days, when it rains etc. :D :D :D
 thanx :y
unlucky alf
  • worksop, notts
« Reply #20 on: 30 March 2009, 13:51:17 »
there was a post a while back showing that by cutting dashboard in a couple of places the matrix will come out easier but i cant find it, but yes it definately sounds like a heater bypass :(
« Reply #21 on: 30 March 2009, 14:17:50 »
Found it :y :y :y :y http://www.omegaowners.com/forum/YaBB.pl?num=1219945946/0
kingplym
« Reply #22 on: 30 March 2009, 20:30:03 »
ahhhhhhhh. SO MUCH THANKS SO MUCH TO ROBG!!!!!!
it took an hour or so but by cutting a hole in the centre console in the drivers foot well i have just managed to remove the matrix!!!
if an administrator reads this any chance you put the section on how to in the technical section?
thanx everyone, thank you so much!!!
Page created in 0.029 seconds with 16 queries.
