Author Topic: overheating  (Read 3726 times)
ians
  • Reading
Re: overheating
« Reply #15 on: 31 March 2009, 15:48:23 »
If you have oil cooler failure, its best not to drive until its fixed.
Do you have an emulsion (creamy) fluid in the expansion tank? Or are you just losing coolant?
DaviesEB
  • Monrovia Liberia
Re: overheating
« Reply #16 on: 31 March 2009, 15:57:53 »
I am having this creamy greasy stuff in the expansion tank.
Used Opel Kadett 1.6 and refurbishing Opel Rekord 2.0
DaviesEB
  • Monrovia Liberia
Re: overheating
« Reply #17 on: 31 March 2009, 15:58:54 »
I am having this creany sludge mixed with the water in the expansion tank.
Cameron
  • Morayshire
Re: overheating
« Reply #18 on: 31 March 2009, 16:59:25 »
Just remember then that the longer you use it like this, more components, like the heater matrix, thermostat and radiator will be getting clogged with gunk...
Re: overheating
« Reply #19 on: 31 March 2009, 17:25:42 »
I'd recommend against using it - not only is that creamy sludge getting everywhere and will be a swine to remove, but it is also DRASTICALLY reducing the cooling efficiency.  And you can't go by the gauge thinking its not getting too hot, as the sensors will be covered in the same mayo, and reading low.
djdaveyp85
  • Halifax, West Yorkshire
  • Geoffrey - RIP!
Re: overheating
« Reply #20 on: 31 March 2009, 17:58:14 »
I will second this asa i drove mine with a failed oil cooler and I'm still suffering from the after effects now! It takes ages to get all the gunk out of your system!
Re: overheating
« Reply #21 on: 31 March 2009, 18:01:51 »
and deteriorating your rubber hoses.  :(
DaviesEB
  • Monrovia Liberia
Re: overheating
« Reply #22 on: 01 April 2009, 09:37:27 »
In this instance, what all do i need to change. The point is that it is pretty hard to find parts out here. Can anyone help me get most of these and let me know the cost of all i need to replace.
I had wanted to flush radiator and open clean cooler and replace with coolant instead of water. Any adhoc solutions. :( :(
