Author Topic: Oil advice and recommendations here  (Read 13704 times)
BruceT
Re: Oil advice and recommendations here
« Reply #15 on: 26 June 2008, 15:34:46 »
I wouldnt mind having my gearbox oil changed as when cold I get a stiff shifting from 1st to 2nd followed by a clunk mid change.
1999 Omega 2.0 16v CD
oilman
  • Sunny Cornwall / UK
    • Opie Oils
« Reply #16 on: 26 June 2008, 16:39:49 »
The requirement is a 75w gear oil
Cheers
Guy
Use the code OMEGA and get 10% Club Discount
oilman's website: http://www.opieoils.co.uk
email: sales@opieoils.co.uk - phone: 01209 202944
« Reply #17 on: 26 June 2008, 16:50:38 »
Guy, what would be the optimum oil for the manual gearbox that you offer and would it be a fully synth?
« Reply #18 on: 26 June 2008, 16:52:21 »
A few other questions.
The autobox requires DexIII on the Omega, is there anything to be gained by using a higher spec oil and if so what?
Also, the power steering uses DexII, again is there anything better than this?
oilman
    • Opie Oils
« Reply #19 on: 26 June 2008, 16:56:45 »
The 75w's here are pretty good tbh, all synthetic if I recall
http://www.opieoils.co.uk/c-668-75w.aspx
Cheers
Guy
oilman
    • Opie Oils
« Reply #20 on: 26 June 2008, 16:58:27 »
The specs are pretty universal, there are some synthetic ones on the market which are better, take a look here.
http://www.opieoils.co.uk/c-767-dexron.aspx
Cheers
Guy
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #21 on: 26 June 2008, 18:48:30 »
Diesels!
What is the difference between an oil intended for petrol engines & those specifically formulated for a Diesel?
Is Comma 10W-40 Diesel any good, that's what been put in mine last service
oilman
    • Opie Oils
« Reply #22 on: 26 June 2008, 19:09:00 »
You need to look at the can for the specs below as most oils cover both petrol and diesel specs ie ACEA A3/B3
A1 Fuel economy petrol
A2 Standard performance level (now obsolete)
A3 High performance and/or extended drain
A4 Reserved for future use in certain direct injection engines
A5 Combines A1 fuel economy with A3 performance
B1 Fuel economy diesel
B2 Standard performance level (now obsolete)
B3 High performance and/or extended drain
B4 For direct injection car diesel engines
B5 Combines B1 fuel economy with B3/B4 performance
C1-04 Petrol and Light duty Diesel engines, based on A5/B5-04 low SAPS, two way catalyst compatible.
C2-04 Petrol and light duty Diesel engines, based on A5/B5-04 mid SAPS, two way catalyst compatible.
C3-04 Petrol and light duty Diesel engines, based on A5/B5-04 mid SAPS, two way catalyst compatible, Higher performance levels due to higher HTHS.
Note: SAPS = Sulphated Ash, Phosphorous and Sulphur.
Put simply, A3/B3, A5/B5 and C3 oils are the better quality, stay in grade performance oils.
Cheers
Guy
oilman
    • Opie Oils
« Reply #23 on: 05 January 2009, 14:07:32 »
Any advice on oil required, please feel free to ask as I can help you
You will also find some useful info on my website here
http://www.opieoils.co.uk/oil-and-filter-service-pack-vauxhall.aspx
All the best for 2009
Cheers
Guy
Omegatoy
  • UK
« Reply #24 on: 05 January 2009, 19:43:52 »
Hmm,
Glad you here to offer advice Guy, so would you recommend an ester based oil for a diesel? or would that be a bit of overkill??
oilman
    • Opie Oils
« Reply #25 on: 02 April 2009, 09:56:18 »
Anyone else for some oil advice? Feel free to ask.
oilman
    • Opie Oils
« Reply #26 on: 05 December 2013, 16:52:35 »
Hi,
Until midnight Sunday we have a 20% SALE on our website with voucher code SALE20
If you need any oil advice then we are here to help! You can contact us here, alternatively give us a call on 01209 202944 Monday - Friday 8.30am to 5.30pm or send us an email to sales@opieoils.co.uk
Cheers
Oilman
oilman
    • Opie Oils
« Reply #27 on: 14 January 2014, 15:04:36 »
Feel free to contact us here for any oil recommendations or any oil related questions you may have.
Alternatively complete our oil recommendation form and we will get back to you asap. You can also give us a call on 01209 202949 Monday - Friday 8.30am - 5.30pm or just drop us an email to sales@opieoils.co.uk
Cheers
oilman
« Reply #28 on: 14 January 2014, 16:35:59 »
Just sent one for my bike (BMW R1200 GS)
I think it can use GM's 10/40 Semi, as I can get it in large amounts at good value.
Very interested in transmission fluid as could do with a change I think  :)
oilman
    • Opie Oils
« Reply #29 on: 25 March 2014, 17:06:26 »
Cheers
oilman
Pages: 1 [2] 3 4  All   Go Up
Page created in 0.023 seconds with 20 queries.
