Author Topic: Handbrake Button Sticking  (Read 1440 times)
damon80
  • Wigan
« on: 03 April 2009, 14:47:36 »
Hi Folks,
Having a bit of a problem with the button on my Mig's handbrake - sometimes it sticks in, and it won't lock into position when pulling it up.  But after pulling it to the top of it's travel a couple of times, it pops out again.
Is there anywhere where it needs oiling??  :-/
Cheers folks  :y
damon80
  • Wigan
Re: Handbrake Button Sticking
« Reply #1 on: 03 April 2009, 19:14:42 »
Anybody?  :'(
« Reply #2 on: 03 April 2009, 19:21:45 »
Anybody?  :'(
My first reaction would be to reach for the WD40 and spray a bit onto / into the button area moving it continually as I would suspect it is sticking due t :Do dryness. 8-) 8-)
Others would disagree with the use of WD40, and would use another lubricant. :D :D :D ;)
The more thorough way is to remove the central consul section and inspect / lube up the handbrake mechanism ::) ::) ::) 8-) 8-) ;)
« Last Edit: 03 April 2009, 19:23:09 by Lizzie_Zoom »
damon80
  • Wigan
« Reply #3 on: 03 April 2009, 19:23:37 »
Cheers Lizzie - worth a whirl I suppose!  :)
I suppose I could get used to the smell of it in the cabin after a bit  :D  ;D
« Reply #4 on: 03 April 2009, 19:24:51 »
Follow this guide Damon if you want to remove the consul:
http://www.omegaowners.com/forum/YaBB.pl?num=1212562967
 :y :y
« Last Edit: 03 April 2009, 19:25:14 by Lizzie_Zoom »
damon80
  • Wigan
« Reply #5 on: 03 April 2009, 19:27:35 »
 :y :y
Marvellous - thanks again Lizzie  :y
Shouldn't be too difficult to remove the centre console - had to take it out on my last Miggy to get rid of all the shite superfluous wiring that our boys in blue had left behind
Page created in 0.009 seconds with 20 queries.
