Author Topic: key fob breaked  (Read 5807 times)
nick v6
  • walsall / west midlands
Re: key fob breaked
« Reply #15 on: 03 April 2009, 18:26:49 »
Nick is THIS any good to you? Get your local locksmith to reprogramme it :y
aint there a certain way to reprogram them
like putting in the ignition fo so long and pressing the button
Welung666
Re: key fob breaked
« Reply #16 on: 03 April 2009, 18:32:22 »
Had a google...
Turn on ignition, Point remote control to the senser located by sun roof controls, Press and hold down remote control button,The interior light should light up to show system as been programmed OR central locking door buttons should click down and up!
Not sure if thats for a new battery or new remote though on the IR type.
« Last Edit: 03 April 2009, 18:32:52 by Welung666 »
Martin_1962
Re: key fob breaked
« Reply #17 on: 03 April 2009, 20:17:26 »
You need tech 2 to reprogram them to a new car, as to the switches - they are a bugger to solder - the 4 pin ones are not easy.
You can seperate the key from the fob then send the fob for a short holiday to have new switches fitted.
Immobiliser chip is attached to the key
« Last Edit: 03 April 2009, 20:17:43 by Martin_1962 »
nick v6
Re: key fob breaked
« Reply #18 on: 03 April 2009, 20:41:07 »
the switch on this key has only 2 prongs
can you pm me on cost to repair/replace the switch
thanks
Martin_1962
Re: key fob breaked
« Reply #19 on: 03 April 2009, 20:47:01 »
Need a photo first.
Not sure which type it is now :y
nick v6
Martin_1962
Re: key fob breaked
« Reply #21 on: 03 April 2009, 21:07:04 »
    • 530D M Sport, 330i Coupe
Re: key fob breaked
« Reply #22 on: 03 April 2009, 22:21:40 »
Infra red type IIRC
nick v6
Re: key fob breaked
« Reply #23 on: 04 April 2009, 07:54:12 »
http://cgi.ebay.com.au/VAUXHALL-OMEGA-TWO-BUTTON-REMOTE-ALARM-KEY-FOB-IR_W0QQitemZ370148558900QQihZ024QQcategoryZ10404QQtcZphotoQQcmdZViewItem
thats the key type
ill post pics tomorrow
Haven't done one of those :(
have you got a rough idea on what it would cost to replace the switch
thanks
Re: key fob breaked
« Reply #24 on: 04 April 2009, 10:26:48 »
Its an IR type, and immobiliser works off the IR as well - no transponders in this type.
Fortunately, it would appear to be easy to bypass immobiliser on these IR types.
