Author Topic: Heater relay  (Read 1327 times)
semisheen
  • Chesterfield
Heater relay
« on: 01 April 2009, 21:07:41 »
Not really sure if the problem is the heater relay anyway here goes ……….
The car will always fire on the button from cold but its like the heater plugs aren’t staying on long enough ….hope im making sense  it initially fires no problem but as soon as I let go on the key it stops after about six attempts it starts no problem and is ok for the rest of the day
Were would I fint the heater relay ?
Any help appreciated
platty
  • Cambridge
    • BMW 530d Sport
Re: Heater relay
« Reply #1 on: 03 April 2009, 22:13:05 »
Have you tried "glowing" 2 or 3 times in a row before trying to start - turn ignition on until little squiggle light goes out and then ign off and repeat 2 or 3 times. If it starts after this then I would say you need some new plugs ~ £30ish  :y
If this doesn't cure it then it might need further investigation..
semisheen
  • Chesterfield
Re: Heater relay
« Reply #2 on: 03 April 2009, 23:47:36 »
Thank you for the reply ............
ive had the heater plugs out today & tested them with the multimeter plus batery chager all glowed red very nicely .......its a strange 1 because the engine always fires straight away but doesent continue
its like as soon as i turn the key it cuts the power to the heater plugs if that makes any sence
Thanks again
George
semisheen
  • Chesterfield
Re: Heater relay
« Reply #3 on: 04 April 2009, 00:32:39 »
startin to talk to myself now ....its gettin late & im off to bed before 1am hopefully .......just though .....what ill do tomorow morning it get the misis to turn it on (the car that is ).and im gonna see how long i get 12v at the heater plugs for ......and then turn it off turn it back on again try to start it & see if and when the 12v disapears
Speak tomorow (whoeavers reading )
George
Omegatoy
  • UK
Re: Heater relay
« Reply #4 on: 04 April 2009, 08:53:42 »
more likely to be a fuel problem from the sound of it,
as in when you continually try to start it the pump is slowly getting enough fuel to keep running, incidentally by glowing it a couple of times the pump in the tank will be energised a couple of times usually enough to fill the injectors and aid starting
very carefully check the leak off pipes if sny doubt replace them all,
including the one from the injector pump :y
semisheen
  • Chesterfield
Re: Heater relay
« Reply #5 on: 04 April 2009, 16:19:20 »
A big thank you  :y ....gave it 3-4 heats this morn started straight away and continued to run ...so by the sounds of it i could be looking at a weak lift pump ....blocked filter in the tank maybe ?
i did the leak of pipes yesterday when i looked at the heater plugs as i had took the inlet manifold of to sort the oil cooler pipes out to say its a rear wheel drive there aint much room under the bonnet
Page created in 0.03 seconds with 20 queries.
