Pages: 1 [2] 3  All   Go Down
Author Topic: oil filter on td help  (Read 5406 times)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: oil filter on td help
« Reply #15 on: 10 March 2009, 11:59:49 »
ok thanks so when i have new part just get it off however then
The best type of socket to use is a 36mm LOW-PROFILE HEXAGON type with a 3/8" square drive.
These are available from good motor factors etc for around 5 quid each.
The more common bi-hexagon sockets simply tend to round-off the nut.
To remove the offending part, try using a strap wrench or start it turning with a chisel.
When you fit the new one, just tighten it firmly - don't 'murder' it up.
The low-profile socket only has a 3/8" drive - so there's the clue!
« Last Edit: 10 March 2009, 12:04:16 by Reliance505 »
« Reply #16 on: 10 March 2009, 12:06:59 »
Will need a decent strap around it to undo.
« Reply #17 on: 10 March 2009, 12:08:19 »
I use a Impact type socket, simply because it was the only 36mm Hex one I could get locally (Halfrauds). Cost about £4 on halfords trade
gazsomega
  • midlands
    • 2.5 Opel estate
« Reply #18 on: 10 March 2009, 13:10:04 »
ive used my mates strap around it he works in a garage and its a good strap but there not much room down there to be honest
Used  to have  two v6 and they roared
Now got 2.5 to Opel
« Reply #19 on: 10 March 2009, 13:15:07 »
more room with intake off ;)
Agemo
  • Cleethorpes
  • Insignia
« Reply #20 on: 10 March 2009, 14:03:32 »
You ARE putting the strap around the TOP bit???  Not the body lower down???  Just a thought.   :o
« Last Edit: 10 March 2009, 14:03:45 by Agemo »
largecol
  • Middlesbrough
  • I cant see my socks!!
« Reply #21 on: 10 March 2009, 17:27:58 »
Hi mate, had exactly the same problem myself last weekend - nut snapped off the top. But but worry ye not - popped down to Halfrauds and bought a chain wrench affair for 6 squids. Fits over top of the plastic cannister with a bit of knuckle scraping and fiddling, but all you need is a 1/2 inch extension and ratchet to turn it. Only took 1/4 turn to loosen it and job was a good`un. MAKE SURE you get the right filter to replace though - theres 2 very similar and i got the wrong one 1st time round. :y :y
Pssssst! The man in my avatar aint really me!!
gazsomega
  • midlands
    • 2.5 Opel estate
« Reply #22 on: 10 March 2009, 22:25:05 »
yeah i put starp around bottom housing of the case still wouldnt turn the strap from hafords do you have a picture all i want to do is change the filter ive done plenty on other cars this has been the hardest ever
Now got 2.5 to Opel
gazsomega
  • midlands
    • 2.5 Opel estate
« Reply #23 on: 10 March 2009, 22:26:29 »
when i say bottom housing i mean its still the same case that is attached to the nut
Now got 2.5 to Opel
Agemo
  • Cleethorpes
  • Insignia
« Reply #24 on: 10 March 2009, 22:33:54 »
OK I think you know what you're doing, just wanted to make sure.  I was looking for a pic earlier without success.  I changed mine the other day, never thought of taking pics.  ::)
gazsomega
  • midlands
    • 2.5 Opel estate
« Reply #25 on: 10 March 2009, 22:38:24 »
i think my only option is to get down vx and get a price on a new one then try and chisel the old one round if i break it then at least it can be replaced
Now got 2.5 to Opel
Agemo
  • Cleethorpes
  • Insignia
« Reply #26 on: 10 March 2009, 22:40:43 »
Yes I agree, no point getting past the point of no return without the parts to finish. It is annoying people tighten plastic bits like this, there is no need. Best of luck.  ::)
gazsomega
  • midlands
    • 2.5 Opel estate
« Reply #27 on: 10 March 2009, 22:43:31 »
im suprised it didnt break putting it on its unreal i think for plastic will post back how i get on
Now got 2.5 to Opel
largecol
  • Middlesbrough
« Reply #28 on: 10 March 2009, 23:03:26 »
Hi Gaz, sorry mate no pics till tomorrow, but i tried my usual strap and couldnt get enough `purchase` on the cannister, also tried the chisel solution but got too scared of breaking it!! got the cheap chain one and it got a much better grip. And yes it did seem stupidly tight!!
gazsomega
  • midlands
    • 2.5 Opel estate
« Reply #29 on: 11 March 2009, 08:59:12 »
just wondering which strap to go buy first and try that as there is a few down there sooner try the one that worked
Now got 2.5 to Opel
Pages: 1 [2] 3  All   Go Up
