Pages: 1 2 [3]  All   Go Down
Author Topic: SNOW  (Read 7866 times)
Re: SNOW
« Reply #30 on: 19 November 2007, 08:55:01 »
Just started SNOWING hear in East Leake  :o
We had none just up the road in West Bridgford.....
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: SNOW
« Reply #31 on: 19 November 2007, 09:44:13 »
Snow has certainly gone now but the sky looks rather full :-?
Paulus
  • Wheaton Aston
  • Are you lookin' at me??? Punk???
Re: SNOW
« Reply #32 on: 19 November 2007, 10:58:17 »
None left in Coventry where I work.
« Last Edit: 19 November 2007, 11:03:09 by Paulus »
Growing old disgracefully...
Bo Bo
  • Coventry
Re: SNOW
« Reply #33 on: 19 November 2007, 13:58:47 »
It rained shortly after the snow settled so didn't last long.....
Re: SNOW
« Reply #34 on: 19 November 2007, 14:07:47 »
Just persisting down here. Has been all day. Not that I'd know, other than the water that was blowing under the garage door while I was changing swearing at Emma's cam belt.  >:(
Anyone got any tips regarding removing stubborn crank pullies? Tried by hand, hitting with hammer, tried a puller, puller with hammer, 1/2 a can of plus gas later no joy. Will have to remove entire pulley (it's a 2 part job like the V6) and separate on the bench. Would have done already if I had a socket the right size for the pulley bolt.  ::)
Bigger Hammer. If it doesn't loosen the pulley, close bonnet and hit that repeatedly. You'll feel much better, and blame the dents on her driving ;D
Re: SNOW
« Reply #35 on: 19 November 2007, 14:52:21 »
Bigger Hammer. If it doesn't loosen the pulley, close bonnet and hit that repeatedly. You'll feel much better, and blame the dents on her driving Grin
It's sounding increasingly like a job for sammy. Handbrake has already been found lacking while trying to undo the crank pulley bolt in 5th gear (no apparent means of locking flywheel).
One of these might help once the bolt's off: http://www.machinemart.co.uk/shop/product/details/cht248-13-pce-harmonic-balance-puller/path/automotive-tools
Re: SNOW
« Reply #36 on: 19 November 2007, 14:59:54 »
Cant you get somebody to put thier foot on the brake.....
I also hope its not like the Omega V6 where it buggers the sprocket if you try the method you are by sheering the woodruff key.
You do realise those bolts are often 200+Nm + angle tighten and require replacing once removed.
Re: SNOW
« Reply #37 on: 19 November 2007, 15:18:57 »
Yep. Planning to do this tonight after getting the wheels on the floor.
Umm. Me too. The early MX5s had very troublesome crank nose / pulley arrangements anyway. This one's a 2000 model and apparently better but i'm still nervous. Depends where all the loads are going when you're grunting on the breaker bar I guess. Through the Woodruff key being less then ideal.
If I could get the outer pulley / vibration damper off I could probably fabricate a tool to lock the crank using its mounting bolts but I can't.  :-/ Then I read reports on various forums that it doesn't come off unless the main crank pulley bolt is removed anyway, which sounds odd but might explain yesterday's lack of progress. Oh, for a decent workshop manual ::)
General consensus if you believe what's on most Mazda forums is to strap a breaker bar onto it and turn the starter key... :o
Haven't come across anyone who's broken anything getting it off, even using the above method, which is encouraging.
This one is 120 lb ft tightening torque, so not too bad in theory but it's just siezed, I think. Oh, well, another dousing in plus gas and some more grunting later...
Doesn't help that the anti-roll bar runs across the front of the engine at pully height. Maybe that'll have to come off  >:(
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: SNOW
« Reply #38 on: 19 November 2007, 15:47:52 »
 I'd normally suggest an oxy-acetelene torch... but since it's an engine part, I'd assume it is a Bad Idea...?
« Last Edit: 19 November 2007, 15:48:19 by PeteG »
Re: SNOW
« Reply #39 on: 19 November 2007, 16:14:04 »
Applied a little heat with a blowtorch, but it's got a vibration damper built into the pulley so didn't want to melt it.
Danny
  • Wigan, Greater Manchester
Re: SNOW
« Reply #40 on: 19 November 2007, 16:15:27 »
i had to have that on my rear camber adjusters that had siezed!!
Pages: 1 2 [3]  All   Go Up
