Author Topic: Heads off, parts required  (Read 2462 times)
Re: Heads off, parts required
« Reply #15 on: 31 March 2009, 11:54:47 »
Valve grinding paste plus grinding stick
This where a bit of your favourite WD-40 comes in handy  ;), makes grinding a lot easier!  :y  :y  :y
« Reply #16 on: 31 March 2009, 13:12:33 »
Nah, a bit of semi synth is what I use
Martin_1962
« Reply #17 on: 01 April 2009, 22:12:27 »
Yep
Manifold to front pipe gaskets (2 copper flake type seals)
Oil cooler sealent (grey goo in a small cartridge tube)
Anti freeze
Oil
Oil Filter
Get a couple of spare hollow bolts from a breaker for the oil cooler pipes/coolant bridge pipes (never needed any yet but, you dont want to get caught wanting)
Oil cooler pipes to cooler metal washers (4 off)
Coolant bridge dowty washers (4 off)
Coolant pipe to block seal (1 off)
Is the crank seal ok? (any sign of oil round the oil pump)
If I remember, I will post the above part numbers up this evening
Then its cleaning stuff.
Emery cloth
Wet and dry
Valve grinding paste plus grinding stick (the rubber perishes on these so if you ahve an old one then check it)
Paint stripper + an old paint brush
Plenty of old cloths and rags.
Have you had a chance yet Mark?
Martin_1962
« Reply #18 on: 03 April 2009, 20:45:38 »
Parts got
Pair of heads for refurbishing and porting
3.0 cams
3.0 inlet divider
head gaskets
24 oil seals
thermostat
coolant transfer pipe
genuine exhaust manifold gaskets
water pump
1/2 tube black goo
Oil cooler and cover plate
Anti freeze
Oil
Oil Filter
Parts On order
1 tube green goo
Parts To get
1 bastard bolt
1 cam belt kit
1 aux belt
Materials got
Wet and dry
Material needed
Emery cloth
Tools to find
1/4" Rachet
1/4" extensions
Cambelt DVD
Tools to get
T60 for cam pullies
Borrow cam belt locking kit
19mm thingy for oil pipes
30mm for tensioner
8mm 1/4" drive
Is that everything?
Now I wonder where my 1/4" drive stuff is?
And where did I put that thermostat?
Martin_1962
« Reply #19 on: 04 April 2009, 11:22:12 »
Parts got
3.0 cams
3.0 inlet divider
head gaskets
24 oil seals
thermostat
water pump
1/2 tube black goo
Anti freeze
Oil
Oil Filter
1 tube green goo
Tools got
T55 x 2
T60
4-14 in 1/4
10-20 in 3/8
10-22 24 in 1/2
Small T and E torx
Torque Wrench
A few spanners
Parts On order
Parts To get
1 bastard bolt
1 cam belt kit
1 aux belt
Materials got
Wet and dry
Material needed
Emery cloth
Tools to find
1/4" Rachet
1/4" extensions
Cambelt DVD
Tools to get
30mm for tensioner
Is that everything?
« Last Edit: 04 April 2009, 21:23:58 by Martin_1962 »
    • 530D M Sport, 330i Coupe
« Reply #20 on: 04 April 2009, 11:58:48 »
Worth getting an Aux belt idler wheel (for the tensioner) or at the least re-greasing the bearings in the original.
Martin_1962
« Reply #21 on: 10 April 2009, 13:10:23 »
Got manifold to downpipe now
