Pages: 1 2 3 4 [5]  All   Go Down
Author Topic: HELP Loads of problems please help me  (Read 10941 times)
colin28
  • Southend-on-sea, Essex
Re: HELP Loads of problems please help me
« Reply #60 on: 08 April 2009, 21:45:22 »
Where do I locate that sensor?
« Reply #61 on: 08 April 2009, 23:27:48 »
MarksDTM posted a photo of sensor locations in this thread ::)
colin28
« Reply #62 on: 10 April 2009, 11:30:46 »
I have checked the sensor leads and there seems to be nothing wrong there,
Guess the next option is to replace the sensor. But how do I know what 1 needs changing? Front?Rear or both?
Any ideas?
« Reply #63 on: 10 April 2009, 11:34:01 »
I had a similar issue with Mick Dundees car, did a lot of live data work and the MAF appeared to be reading low.
Borrowed the one off Webby's car and it made a big difference so replaced it yesterday adn all is good.
It was a bigger to diagnose and had no fault codes showing.
Fortunately the MAF was sub 30 quid delivered
A simple test was to disconnect it, this made starting and idling much improved as the ECU defaulted to a pre-set value
« Last Edit: 10 April 2009, 11:35:01 by Mark »
colin28
« Reply #64 on: 10 April 2009, 11:59:44 »
So in layman terms disconnect and the front for example and see if there is an improvement. If it is then replace the front...
« Reply #65 on: 10 April 2009, 12:19:30 »
Yep.....
colin28
« Reply #66 on: 11 April 2009, 15:34:27 »
I just drove the car 1/2 mile without disconnecting my sensors, and ALL my fault codes have returned.
0130
0300
0301
0303
0305
This is after 4 coil changes, spark plugs replaces, camshaft sensor changed.
What can it be? no-one seems to know!?
Anymore ideas apart from blowing the shitty car up
Pages: 1 2 3 4 [5]  All   Go Up
