Author Topic: Oil cooler parts  (Read 1040 times)
Martin_1962
Oil cooler parts
« on: 10 April 2009, 12:55:53 »
OK got EPC printout
Got cooler - 2
Lid - 3
4 washers - 15
I do not have seal - 6
I think I have 2 x seals - 4
EPC says I do not need seal 6 for 2.6 ::)
Where are the Dowty washers?
Re: Oil cooler parts
« Reply #1 on: 10 April 2009, 13:49:19 »
Reference drawing?
You should have
Cooler
Cooler plate
2 rubber O rings
2 new nuts
There in the 'kit'
You should also have 4 metal O rings for the cooler pipes
In addition there are 4 dowty washers for the coolant bridge at the rear of the heads.
Martin_1962
« Reply #2 on: 10 April 2009, 17:26:09 »
Reference drawing?
You should have
Cooler
Cooler plate
2 rubber O rings
2 new nuts
There in the 'kit'
Kit was lid and cooler.
4 washers and gunge from VX
so need coolant bridge washers, 2 nuts, 2 seals.
What about the seal between lid & block?
Martin_1962
« Reply #3 on: 10 April 2009, 17:26:59 »
E56
Martin_1962
« Reply #4 on: 11 April 2009, 11:05:05 »
Rechecked - I have 2 x seals 4 and 2x nuts 5 or drawing E56.
No seal 6
« Reply #5 on: 11 April 2009, 15:37:10 »
Reference drawing?
You should have
Cooler
Cooler plate
2 rubber O rings
2 new nuts
There in the 'kit'
Grey Sealant Vx Part Nş 93165267 @ around £7 on TC.  You'll need a mastic gun to apply it & let it go off for 24 hours before refilling system.
