Author Topic: towing indicator warning light  (Read 4455 times)
Re: towing indicator warning light
« Reply #15 on: 26 March 2009, 11:59:48 »
just use the boot beeper its much simpler and as said for the time its going be used...
What's simpler than swapping a reay one for one & putting a lamp in the dash?  :-/ A buzzer is the most annoying thing in the world!  ;)
TBH from inside the car I can barely hear mine with the radio on at a sensible level and conversation with SWMBO ::) ::) ::)
That said, I must get around to sorting the light on the dash as I like everything to work :y :y :y
Myonly gripe with the four terminal flasher is that it's noisier than the origninal 3 terminal (I've found my original now MarksDTM & it does only have 3  ;)) Hella says it's meant to be.  :-/
caran10
  • coventry
« Reply #16 on: 26 March 2009, 19:37:29 »
errr what's what wrong with your mirrors? what's the point in a led on the dash when there is a massive white burger van behind you?
i dont think you can get mirrors that will let you look at the rear of your trailer
caran10
  • coventry
« Reply #17 on: 26 March 2009, 20:00:42 »
Hi i have an omega 2.6 and i tow a caravan with it ,can any one tell me how to get the indicator warning light to flash when indicating while towing (the one on the dash that looks like a towball ) someone told me to change the flasher unit to a 4 pin one i tried bthis but it still doesnt work
grateful for any advice
Have you put a bulb in the dash as you need to.
thanx i'll try that
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
« Reply #18 on: 27 March 2009, 10:45:05 »
where can i get a 4 pin flasher realay any p/n thanks
2001 MV6 3.2 manual been converted from 2.6 auto
« Reply #19 on: 27 March 2009, 11:27:14 »
Halfords or a local towbar specialist.
caran10
  • coventry
« Reply #20 on: 11 April 2009, 06:29:02 »
just got round to checking for bulb and that was the problem works fine now
]many thanks
« Reply #21 on: 11 April 2009, 10:28:17 »
There is no bulb fitted in dash as it leaves the factory. So unless somebody has put one in.... ;)
Jelunga
  • Hailsham
« Reply #22 on: 12 April 2009, 01:15:21 »
Do let me know how you get on. I have the same problem, and like you, I like evrything to work, to factory spec with nothing buggered about with!oops, pardon my french
