Author Topic: Door Check Washers  (Read 3906 times)
Re: Door Check Washers
« Reply #15 on: 12 April 2009, 13:20:52 »
If lots of play in washer, most likely bush.
Despite the fact I order these about 100 at a time, I'm nearly out :o
There seems to be slight movement at the washer / bush and gives the cracking sound. Looks like a yellow or white disk .  I should maybe swap for the passenger one till i get new ones  :y
I found, as unfortunately you may, that changing the washer is too little too late.  The cracking sound was just that, as the metal mounting was divorcing itself from the main door frame!!  It was too late for washers!! ::) ::) ::) ::)
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #16 on: 12 April 2009, 13:21:59 »
If you're really stuck, I can throw one in the post.
That would be very kind .... how can i arrange some kind of payment ?
Proz
« Reply #17 on: 12 April 2009, 13:23:08 »
Mine still seems sound at the attachment so hopefully i will get it fixed in time  :y
« Reply #18 on: 12 April 2009, 13:23:56 »
FFS, they are only 20p!
PM me address, I'll get it in post today - not that it will go until Tuesday I suspect.  Is it just the 1 you need?
« Reply #19 on: 12 April 2009, 13:25:22 »
That's good Proz!  However so did mine until after fitting the new washer.........crack, it all went! :o :o ::) :D ;)
Proz
« Reply #20 on: 12 April 2009, 13:28:35 »
Pm'd ... thank you  :y
Proz
« Reply #21 on: 12 April 2009, 13:33:50 »
My first mig did it from the day i bought it and i never thought anything about it , did it for 5 years  :) ... i wish id found this site before it had a meeting of pistons and valves though  ;D
« Reply #22 on: 12 April 2009, 13:35:24 »
Ouch!! :'( :'(  Now that is a real problem :D :D ;).
hotel21
  • The Kingdom of Fife
« Reply #23 on: 12 April 2009, 17:48:32 »
I'll drop one into your letter box tomorrow Proz, I have a few left in the garage.....     ;)
Jaime - forget the letter, I'll sort from here....   :y
Proz
« Reply #24 on: 12 April 2009, 18:21:47 »
Many thanks  :y
« Reply #25 on: 12 April 2009, 18:33:54 »
Too late - at least he has a spare ;D
That'll be the most expensive washer I've ever given away - I had to educate the printer (and ended up hand wwriting the envelope!). I'm now high on glue though  :-[
;D
Proz
« Reply #26 on: 12 April 2009, 18:35:06 »
;D
Stop it ..... im feeling guilty now  :-[ :-[ :P
