Pages: 1 [2] 3  All   Go Down
Author Topic: lpg install - vapourisor coolent plumbing.  (Read 4138 times)
Re: lpg install - vapourisor coolent plumbing.
« Reply #15 on: 10 April 2009, 14:43:04 »
I got them from Vehicle Wiring products, IIRC. Should get them from a decent motor factors, though, if in a hurry.
« Reply #16 on: 10 April 2009, 14:53:34 »
cheers Kev. :-)
« Reply #17 on: 10 April 2009, 17:14:22 »
cheers Kev. :-)
Just been rummaging in the garage and I have some left over if you have trouble finding any.
Seems I bought a few last time I was LPG'ing.
Martin_1962
« Reply #18 on: 10 April 2009, 17:29:03 »
Romano kit and the bore is not that big
Re: lpg install - vapourisor coolent plumbing n stuff
« Reply #19 on: 10 April 2009, 19:21:28 »
cheers Kev. :-)
Got some mate but thanks for looking. BnQ beleive it or not, 19mill polly. And a load of other tat that mite have done. But the 19 mill just about fitted with a fight. It had even stopped raining by the time i got back.
 Went well in the end. Didnt even remove the hbv just cut the pipe with a knife and poked the elbow in. Vap  mounted to wing, coolent pipes plumbed in and inlet manifolds back on.
Loom and fuel pipes to injectors in the morning...well, lunch time hopefully. :-)
Did you see my post re ecu sighting and loom root(roughly)? And will i def have to remove the injector loom cable tray ? Left it no for the min incase they get mixed up.
Cheers guys.
Chris :-)
« Last Edit: 11 April 2009, 15:05:06 by chrisgixer »
« Reply #20 on: 10 April 2009, 19:32:21 »
cheers Kev. :-)
Cheers guys.
Chris :-)
Makes Life easier if you remove the cable tray :y :y
I mounted my ECU behind the bumper with the S/L pump but it's tight on space and loom length ::) ::)
I routed the loom accross the front of the engine and into the V for injectors and accross behind the bumper for Engine ECU connectors
« Reply #21 on: 11 April 2009, 14:56:35 »
ok ready for the plenum to go back on, except i cant bring myself to drill a hole in it (plenum) for the vac feed to vap is it? (brass cross piece in line with the fuel line)
Anyway, is there anywhere else i can run it from? i hate making ireversable changes to expensive bits of metal :'(
« Reply #22 on: 11 April 2009, 19:19:40 »
I take it that a no then? :-)
« Reply #23 on: 11 April 2009, 19:29:26 »
Sorry... Was busy earlier when I saw this!
I believe you can take it from any vac line as it is only a reference but... Drilling and tapping the plenum is a tried and tested location... You've already drilled and tapped the manifold so why worry about this one?
« Reply #24 on: 11 April 2009, 19:58:25 »
im a big girly poof is why.... ;D   got to cut into the wires by ecu yet, im dredding it  :-/
so should bo ok if i pinch a bit off vac from the cars existing vac system....somehow....bit of pipe for joins and a tee off maybe  :-?
got the manifold this morning by the way. :y :y :y :y
« Reply #25 on: 11 April 2009, 20:06:41 »
IIRCC there's a cople of plastic T's for vac pipes in the kit but TBH I'd take it from the plenum... That way it can't interfere with anything and nothing can interfere with it :y :y :y
Don't be such a poof... It's easier than drilling/tapping the manifold for injectors :y :y :y
As for the ECU wires... If you have enough slack in the loom then solder straight to the back of the pins... I didn't quite have enough so I just stripped the insulation back and soldered the wire onto it... Then re insulated... Job done :y :y :y
« Reply #26 on: 11 April 2009, 20:18:16 »
The vac pipes already there give an accurate vac reading. T off those.
« Reply #27 on: 11 April 2009, 21:21:29 »
Cheers mark, was thinking to try it and see. If no good then can tap the plenum later.  :y
« Reply #28 on: 12 April 2009, 00:39:25 »
Make sure you don't put the tee downstream of a reservoir though, or it will not be happy. Take it straight from the tee in the brake servo hose.
« Reply #29 on: 12 April 2009, 00:48:09 »
Exactly what i had in mind.  ;)
Pages: 1 [2] 3  All   Go Up
