Author Topic: Codes - coil pack or plugs  (Read 963 times)
Martin_1962
« on: 15 April 2009, 13:49:08 »
1700
0300
0303
0305
stopped counting then
Re: Codes - coil pack or plugs
« Reply #1 on: 15 April 2009, 13:58:36 »
MAF?
Plugs should be easy enough to check, coil is unlikely as you would expect 2 to fail at the same time
Martin_1962
« Reply #2 on: 15 April 2009, 14:06:16 »
MAF?
Facelift - coil per plug!
I'll pop out a plug one evening.
MAF - aghhhhhh
Where from & how much!
« Reply #3 on: 15 April 2009, 14:07:51 »
MAF?
MAF - aghhhhhh
My mistake, I miss typed.
It should have said 'coil is unlikely as you would not expect 2 to fail at the same time '
Martin_1962
« Reply #4 on: 15 April 2009, 14:22:03 »
£3.36+VAT at the dealer for plugs so not too bad
I iwll have to check one evening
