Author Topic: dripping water  (Read 1818 times)
Beconboy
  • DAGENHAM
    • 2000 3.0 OMEGA ELITE
dripping water
« on: 15 April 2009, 14:27:35 »
as in title dripping fromfront of car on passenger side near radiator any ideas of were it can drip from other than rad what pipes are there
   thanks Gary
Agemo
  • Cleethorpes
  • Insignia
Re: dripping water
« Reply #1 on: 15 April 2009, 15:06:07 »
I bet it's dripping off the air-con condenser. If it's coolant, you will smell the anti-freeze.  ::)
« Last Edit: 15 April 2009, 15:06:20 by Agemo »
Re: dripping water
« Reply #2 on: 15 April 2009, 15:16:00 »
It wont be off the aircon condenser as that is hot ! (its the evaporator thats cold)
Check the hoses to the rad for leaks and the drain plug at the base of the rad to.
Beconboy
  • DAGENHAM
Re: dripping water
« Reply #3 on: 15 April 2009, 15:18:50 »
checked hoses still dripping all the time
Beconboy
  • DAGENHAM
Re: dripping water
« Reply #4 on: 15 April 2009, 15:19:22 »
drain plug also ok
amba
  • Medway towns
    • German V6
Re: dripping water
« Reply #5 on: 15 April 2009, 16:27:32 »
Had similar mysterious drip of coolant from mine last year..ended up replacing the radiator and has cured it...expect it is a pin hole at the bottom...don,t be tempted to put rad seal in the system though.
Beconboy
  • DAGENHAM
Re: dripping water
« Reply #6 on: 15 April 2009, 16:31:47 »
cheers for reply  :y cold someone tell me part no for 3.2 rad for mv6 elite estate 2001
     plate         Gary
