Author Topic: Newbie to Migs  (Read 3670 times)
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: Newbie to Migs
« Reply #15 on: 17 April 2009, 00:15:02 »
Check the wishbones.
I had a full geometric two weeks ago and the car is still pulling slightly to the left. I have my suspicions that it's a worn front bush on the l/h wishbone. I changed them when I bought the car about two years ago and that would tie in with the time scale they usually last me.
Had a similar issue during a geometric set up a few years ago. The car was spot on when I took it out to test it and once the brakes had been applied the tracking would be out by a fair bit. Jacked the car up and let it down again and the tracking was spot on again. Only out when the weight bias was to the front under braking. New wishbones sorted that out.
Does anyone have the dimensions of the front bush ?
I'd like to get poly-bushes made up. I had kept the old wishbones intending to get the dimensions but just can't find them.
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: Newbie to Migs
« Reply #16 on: 17 April 2009, 01:55:49 »
Just to add my two cents - if the n/s/f tyre is wearing on the inside edge then I reckon you need a new steering idler - £30 off fleabay and about an hour to replace.
Rear springs - I got mine from buypartsby, at £35 each (KYB RJ6227, but they were rear springs for a facelift saloon with self levelling suspension). Took me about six hours to fit, but that was my first crack at doing them (following Marks DTM's guide) and included popping out to buy spring compressors halfway through (you WILL need them!).
Parts are cheap, the work is easy to do, and you have a FREE car! Nice one, mate! :y
I dropped the diff slightly. The springs will then go in without compression.
With the car on axle stands, put a jack underneath the diff for support and to control the lowering and raising. If I remember right, there are four bolts securing the diff and something rings a bell about disconnecting abs leads. If all goes to plan, shocks and springs should be comfortably done in an hour and a half.
