Author Topic: fault code  (Read 1405 times)
beefy
fault code
« on: 17 April 2009, 11:22:01 »
hi guy's please help i have a fault code P0705706 i understand that the P0705 stands for transmission range snsor,  but not to sure what the 706 stands for please help, cheers beefy
Welung666
Re: fault code
« Reply #1 on: 17 April 2009, 11:25:59 »
P0705 = Invalid Signal from TCM (Transmission Control Module)
P0706 = Transmission Range Sensor Circuit Range/Performance
HTH :y
beefy
Re: fault code
« Reply #2 on: 17 April 2009, 11:31:40 »
cheers Welung666 you may call me thick, the code is P0705706 dose that mean both of these faults, or just one of them cheers, mate beefy
Welung666
Re: fault code
« Reply #3 on: 17 April 2009, 11:35:51 »
I'm guessing you missed a 10 flash somewhere along the way, if they are both showing then they're both a fault but most likely connected. Fix 1 and the other will go.
beefy
Re: fault code
« Reply #4 on: 17 April 2009, 11:51:37 »
ok cheers buddy
