Author Topic: black sealant for crankcase breather - how to cure  (Read 2054 times)
x1xv45
« on: 14 April 2009, 17:31:32 »
I put the crankcase breather pipe (the one that comes down from the rocker cover at the back/right) back on with a new gasket, but it still leaked.  Now I did it over with the vauxhall black sealant (and no gasket). What should I do now - let it sit? For how long? Or heat it up? Or just drive it?
Re: black sealant for crankcase breather - how to cure
« Reply #1 on: 14 April 2009, 21:22:55 »
not familiar with the 4 pot personally. Maybe someone will know.
 What black goo is it? Does it have a number, drying times can vary depending...?
« Reply #2 on: 14 April 2009, 21:28:18 »
If its the same sealent as the cam covers than an hour or 2 will be more than enough as the actual thickness will be very small
x1xv45
« Reply #3 on: 14 April 2009, 22:19:58 »
It's the vauxhall sump sealant, part no. 90485251, as rec. on this forum.
On the tube there's a clock at 5 minutes to 12, which I thought might be Vauxhall's opaque way of saying 5 minutes curing time. I'll be leaving it overnight, so I'll post the results tomorrow.
x1xv45
« Reply #4 on: 16 April 2009, 12:28:41 »
Well, I've driven about 60 miles with it and it looks dry - before it would be pooling, dripping and generally coating the underside with a film of oil. So if it holds, I can recommend the black goo (90485251) as a substitute for a new gasket, which did no good.
I'd also recommend an orangutan to do this job, or someone with similarly long, bendy arms - really hard to get your hands on this, and you need to work blind most of the time.
« Reply #5 on: 16 April 2009, 12:34:54 »
Sounds as though you have had a good result Frank! :y :y  Well done ;) ;)
You should try working on a V6 to find out how working blind and in awkward positions is like! ;D ;D ;D ;D ;D ;)
Omega man 2
« Reply #6 on: 16 April 2009, 13:23:51 »
Well we've a 4 pot and a v6 and I've done loads of work on both and I have to say that the biggest blind spots I've come across are on the 4 pot between that pipe and the exhaust manifold. :D
Still, the v6 looks alot more scary to work on ::)
« Reply #7 on: 16 April 2009, 13:29:31 »
Fair enough Omega-man! ;) ;)
All I know is compared to all the four pots I have worked on, including Carlton's, let alone straight six's like Senator's, my V6 has already proved very awkward in many ways.
Just getting to the plugs is bad enough, let alone that blessed HBV and the passenger bank cam cover casket.....oh and even the oil filter being only accessible from underneath the car! ::) ::) :D :D ;)
My poor fingers and knuckles, it has cost a fortune in creams! ;D ;D ;D ;)
« Last Edit: 16 April 2009, 13:29:58 by Lizzie_Zoom »
« Reply #8 on: 16 April 2009, 14:32:30 »
If you remove a few bits off the V6 then access to everything is very easy....look:
« Reply #9 on: 16 April 2009, 14:36:27 »
very good Mark ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D :y :y
Yes gone are the days when all you had to do was open the bonnet and plugs, distributor, carburetor, oil filter, even rockers, etc, was all there for the taking!! :D :D ;)
Where's my Cortina?? ;D ;D ;)
« Last Edit: 16 April 2009, 14:37:40 by Lizzie_Zoom »
Martin_1962
« Reply #10 on: 16 April 2009, 14:49:53 »
How do you remove the metal pipe above the manifold on the drivers side?
x1xv45
« Reply #11 on: 16 April 2009, 22:21:24 »
I would like to rip out the air conditioning altogether - lots of room in there with that out - but I'm told that is never going to work. True or not?
Martin_1962
« Reply #12 on: 17 April 2009, 09:18:08 »
I wouldn't - AFAIC Aircon is essential
    • 530D M Sport, 330i Coupe
« Reply #13 on: 17 April 2009, 09:30:43 »
If you use a 2.0 Aux belt you can then bypass driving the Compressor.
andyc
  • Norfolk
« Reply #14 on: 17 April 2009, 12:26:45 »
If you haven't re-fitted the gasket that will be part of the reason. Fit a new gasket with sealant ob both side and make sure both faces are clean.
Andy
Thetford. Norfolk
