Author Topic: 2.6 Engine swap  (Read 1486 times)
Rob_G
2.6 Engine swap
« on: 20 November 2007, 18:16:02 »
Hi again guys , Ihad a problem recently with sludge pouring out of header tank , have looked in to it by taking cams , heads off etc and r/h/s pistons have started to (well best way to put it ) melt , have located a 2.6 from a 2001 Vectra , is it just a case of unbolting all ancillaries from Omega engine and bolting them to Vectra block/head , thanks  again , Rob
STMO123
Re: 2.6 Engine swap
« Reply #1 on: 20 November 2007, 18:17:07 »
I'm no expert but I'd say NO!
STMO123
Re: 2.6 Engine swap
« Reply #2 on: 20 November 2007, 18:18:13 »
See Russ. Put a few words before the NO!. ;D
Jay w
  • Plymouth/Poole
  • omega gone
Re: 2.6 Engine swap
« Reply #3 on: 20 November 2007, 18:25:58 »
again, im no expert but i would imagine the bare block would be the same, the sump would be different as would the induction...
mark_dtm is the man on this
STMO123
Re: 2.6 Engine swap
« Reply #4 on: 20 November 2007, 18:27:47 »
I seem to remember Mark saying that the bolt holes for various ancilleries were in different places and of a different depth.
Re: 2.6 Engine swap
« Reply #5 on: 20 November 2007, 18:33:26 »
I think it will be OK, the blocks are the same...
STMO123
Re: 2.6 Engine swap
« Reply #6 on: 20 November 2007, 18:36:06 »
There you go...that's what I said :y
 ;D ;D ;D
Re: 2.6 Engine swap
« Reply #7 on: 20 November 2007, 18:40:21 »
all ancils, sump, inlets, camcovers, the lot will have to be changed over.... while it's doable, would be easier to source an Omega lump.
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: 2.6 Engine swap
« Reply #8 on: 20 November 2007, 18:45:03 »
what model omega do you have? 2.6 is fly by wire...
Re: 2.6 Engine swap
« Reply #9 on: 20 November 2007, 18:50:40 »
Blocks and heads are the same....sumps, cam covers and ancillary mounts are different.
Easy enough to sort with both engines side by side.
davlad22
  • Sunny Yorkshire
Re: 2.6 Engine swap
« Reply #10 on: 20 November 2007, 19:34:37 »
Not the well documented 'oil cooler scenario' then??? All the best with the work  :y
