Author Topic: timing chain or no t/chain that is the question  (Read 4846 times)
Re: timing chain or no t/chain that is the question
« Reply #15 on: 18 April 2009, 13:34:37 »
Thanks for that TB and Mark! :y :y
I do now understand what you mean, and I suppose it is just my preference for something made of metal of something of rubber ::) ::) ::)    But of course technology moves on and so do the complexities our all mechanic devices.  These now require a 21st century approach, and not 19th century thinking. 8-) 8-) 8-)
But I am a steam power girl after all!! ::) ::) :D :D ;)
« Reply #16 on: 18 April 2009, 18:16:38 »
Yes but, the belts are not just rubber, they have a kevlar core (and are bloody hard to cut!)
kjf7
  • lincolnshire
« Reply #17 on: 21 April 2009, 23:39:52 »
well thanks everyone the cars now done 119'000 so do the chains need replacing the old owner (a mate) said the belts were changed but cant find recipt was he stiched up i know he has'nt me as he did'nt want to sell it to me really :y
CBH
  • West Sussex
« Reply #18 on: 22 April 2009, 10:07:10 »
Belts also reduce the rotating masses in the engine and were first used on high performace race engines before getting on to road cars. This enables the engine to change RPM quicker and with less strain on the bearings
Cybertrucker
  • Lichfield, Staffs
« Reply #19 on: 22 April 2009, 10:32:24 »
You come across more cars where the rubber bands have snapped than you ever did with chains snapping.
One thing I would recomend, from personal experience, is if you take a belt off for some reason (eg head off) don't put it back on again.  We replaced the camshaft on my Dad's Cortina many years ago (it had developed the classic Pinto engine death-rattle!) and on re-assembly we looked at the cam belt and decided it was okay.  Bad move - it snapped less than a week later, fortunately without causing valves and pistons to fight and killing the engine.
Okay, I'm prepared to accept that belt technology has improved in the last 25 years, but ever since then I've adopted the principle that if I take a belt off it goes in the bin.
Incidentally, although I've not known many belts snapping (apart from that one!) I've seen a lot of belts that have badly worn teeth, to the extent that some teeth are missing completely.  If you get too much of that your belt can jump over one of its sprockets and put your timing out, and in extreme cases it could put your timing so far out that valves and pistons can try to be in the same place at the same time, with disastrous consequences!  :o
« Last Edit: 22 April 2009, 10:35:39 by cybertrucker »
http://www.cybertrucker.co.uk - Truck stuff
http://www.abd.org.uk - Association of British Drivers
My other car is a Granada.
My other other car is a Dennis.
« Reply #20 on: 22 April 2009, 10:46:18 »
I suppose they're better than the Essex engine's fibre gear. It did make them quieter, especially when they stripped their teeth & the engine died!  ;D
CBH
  • West Sussex
« Reply #21 on: 22 April 2009, 11:17:34 »
Essex engine was a great engine a bit heavy but bullit proof.
I used to build and race these and always changed the cam drive gear for a metal one supplied by swaymer racing. On a good 3l road engine you could get 180BHP and on a racing one around 240BHP but I always wanted a Cosworth GAA engine based on an ESSEX block with dual cams per bank, belt driven and was around 500BHP
« Reply #22 on: 22 April 2009, 11:41:41 »
Didn't know you could get those kind of bhp's from them,
I wonder if my Dad will let me play with his 2.3 ?   ;D  ;D  ;D
« Reply #23 on: 22 April 2009, 11:45:41 »
You can get those figures from any engine if you throw money at it (i.e. the 500bhp would be expensive).
Trouble with the Essex is that its not a powerful engine out the box and even when tuned up its pretty shite......
30 years ago it could hold its own, in the 80's it was past its best and in the 90's it was anchor fodder!
« Reply #24 on: 22 April 2009, 12:07:03 »
Which is why it's been superceded many times .....  :y
CBH
  • West Sussex
« Reply #25 on: 22 April 2009, 12:11:27 »
You are right we were racing Capris in the 70's
We used Holley carbs on the road engines.
The most expensive part of the race engine was the triple webber setup on the Ford X manfold
The 2.3l and 2.9l were Cologne engines not an Essex these had only two inlet ports per head instead of 3.
The Essex was a cut down Ford V8 that had being designed as a deisel that why it was so heavy
over50now
  • Hertfordshire
« Reply #26 on: 22 April 2009, 23:00:05 »
My 2006 Astra 1.4 has got a timing chain.   3 days before Christmas, had to have new chain fitted (£450) (Had 44k on the clock). My Mechanic checked with local VX dealer to see if there was a recall.
Had following answer "Nope, but we have just done 8 of those Astras in the past few weeks with 40K on the clock"
Think according to service scheds, 80k should be done.
chain or belt.       or workmanship
IAM & ROSPA Gold Grade driver
« Reply #27 on: 22 April 2009, 23:02:47 »
probably the stupid 20k service interval
« Reply #28 on: 23 April 2009, 02:21:43 »
seen an Alpha 147 twin spark with a head full of bent valves. You could see the valve marks in the pistons with spark plugs removed. Belt was still on, just no teeth on it. They where all sat in the bottom of the belt cover. Those engines borderline ,iirc it had done about 500 miles over the recommended belt life. Wrote the car off.
« Reply #29 on: 23 April 2009, 10:09:32 »
I remember a couple of test drives when my dad was looking to change his car in the early 90's. 2.9 12v Cologne engined Scorpio (seiously asthmatic) followed by Senator 3.0 24v. Felt like the hand brake had been taken off when we got into the Senator! :o Guess what he bought?
It's interesting how some manufacturers alternate between belt and chain. Ford surprised me with the Zetec-E engines. They engineer a perfectly reliable belt setup that is spec'ed for 100k/10 years (and they very rarely fail within that period). Average Ford owners generally aren't the most dilligent at servicing - so find any weaknesses if they exist.
What do they do? Replace it with a chain driven engine! ::)
The fact is, both will suffer if neglected and both need some maintenance, although the belt change intervals on the GM engines is disproportionately frequent.
Belts are a lot easier to service than chains.
I'd much rather buy a car with a belt, change the belt and know that everything is OK than wonder how dilligent the DPO has been with oil changes on a chain setup.
