Pages: 1 2 3 4 5 [6]   Go Down
Author Topic: 2.5TD poor starting  (Read 11024 times)
Re: 2.5TD poor starting
« Reply #75 on: 27 April 2009, 10:17:43 »
Fuel filter is bolted to OSF wing, about 4" in diameter, 6" long.
ali
  • hertfordshire
« Reply #76 on: 27 April 2009, 11:57:51 »
As its still raining want to check this is the right thing before getting wet :D
If this is it, you guessed it ;) ;) Next question how do I get it off? Found  plastic thing underneath, lots of bolts on top?
« Reply #77 on: 27 April 2009, 13:15:39 »
Yup :y
Unscrews like an old fashion oil filter.  May need to undo bolts holding cap to wing to give extra clearance
ali
  • hertfordshire
« Reply #78 on: 27 April 2009, 13:19:45 »
ok, still raining but will give it a go when I can. I have been having trouble with the key remotes, this wouldnt have anything to do with it? I had one car that if the blippy thing didnt work then engine wouldnt turn over.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #79 on: 27 April 2009, 13:25:26 »
Yep ali, that's the beggar!
Easiest way that I find to do it is by removing the complete unit from the inner wing - thus:
1) Remove both fuel pipes on the filter head. Don't lose the copper washers - 4 in total!
2) Unclip and release both wiring multi-plugs. Note their orientation.
3) Remove the two captive bolts that secure the filter head to the wing.
4) Lift out the complete filter assembly.
5) Carefully grip the filter head in a vice, (or Workmate etc), and unscrew the filter from the head.
6) Fill the filter with fresh fuel, and screw it back on to the head. Don't go mad, just screw it on firmly.
7) Keep the unit vertical, and carefully refit it to the wing.
8) Reconnect the wiring and pipes.
9) Now slacken-off, (say a half-turn), each of the six injector pipes at the injectors.
10) Crank the engine over, until you see diesel spirting from the injector pipe ends. Don't get close, as this is high pressure stuff here!
11) Once fuel is seen, stop cranking, and tighten the injector pipes.
12) Turn the key, allow the glow-plug light to extinguish, and voila, it should start and run.
« Reply #80 on: 27 April 2009, 14:01:02 »
Is it the infra red type, or RF type remote (if unsure, what year is it?)
ali
  • hertfordshire
« Reply #81 on: 27 April 2009, 16:34:54 »
Syd is back to life ;D ;D ;D ;D ;D ;D ;D ;D ;D thankyou
But when I needed to fill filter I took back out fuel pump and got diesel that way, after 2 pumps it stopped and lost power again :( a bit of a fiddle and got it going again :) So not sure if pump is on way out or just loose cable? Im off to see how much a new pump and filter is as at the moment the broken filter is wedged on :D Oh and now my fuel needle doesnt work but I think I forgot to re connect the cable :o
At least now I can stop bugging you all until the next job ;)
Cybertrucker
  • Lichfield, Staffs
« Reply #82 on: 27 April 2009, 17:20:50 »
Excellent!  Well done.  You are hereby awarded the Order of Cybertrucker for courage and perseverance in the field of Omege repair, and for being generally brilliant.
You can bug us as much as you like!  I've learnt a lot from this thread, which will be very useful on my Miggy if I ever have to do the same jobs and can't persuade you to come and do it for me!  ;)
ps  Um, what are you like on replacing ABS control units and headlights...?
http://www.cybertrucker.co.uk - Truck stuff
http://www.abd.org.uk - Association of British Drivers
My other car is a Granada.
My other other car is a Dennis.
« Reply #83 on: 27 April 2009, 18:33:45 »
Headlights, nice and easy.
ABS, never done myself, but, err, 'fiddly' by all accounts ;D
Pages: 1 2 3 4 5 [6]   Go Up
Page created in 0.012 seconds with 14 queries.
