Author Topic: Thermostat and link pipe  (Read 3724 times)
ScottieMV6
  • Swinton, Manchester
Re: Thermostat and link pipe
« Reply #15 on: 30 April 2009, 14:40:45 »
I am pretty sure its the right bolt but I will check if I have any others anywhere.
I'd rather be scared to death than bored to death!!
« Reply #16 on: 30 April 2009, 14:47:43 »
It should fit as lifting eye, dip stick tube bracket and then transfer pipe.
The bolt should have a spacer on it that about 8mm deep.....is this present?
ScottieMV6
« Reply #17 on: 30 April 2009, 15:49:48 »
The spacer is definitely there and I have them in the order you have said.
If I get a shorter bolt and it tightens everything up will it be safe to use it.
ScottieMV6
« Reply #18 on: 01 May 2009, 14:10:21 »
Right. Got the damn thing fitted but with a much shorter bolt and no spacer. Absolutely no play in the transfer pipe at all.
Will this work ok or am I likely to be stripping it down again to fix a water leak in the near future? :'(
« Reply #19 on: 01 May 2009, 14:19:10 »
Should be fine.
Cant work out how you ended up with a longer bolt though!
ScottieMV6
« Reply #20 on: 01 May 2009, 14:30:17 »
No neither can I!! I thought I had been really careful when I took everything off in making sure I knew where to put it back.
Fingers crossed then. Thanks Mark. :y
