Author Topic: Rear Shocks  (Read 1944 times)
a2reed
  • Battersea London
Rear Shocks
« on: 01 May 2009, 20:53:54 »
Just ben and had a new exhaust fitted and the guys there said my rear shocks are gone... had a look myself and they are both definately leaking....anyone done this on and Elite Saloon and the garage told me £700....!!!
Bent valve
Re: Rear Shocks
« Reply #1 on: 01 May 2009, 21:04:31 »
 Years ago it used to be standard practice at fast fit centres when going in for a new exhaust or tyres to spray the shockers with wd 40 or similar, then invite the customer to come and look for himself to see how knackered they were , and by the way they just happened to have some of those dampers in stock at  a very reasonable price.... ;)
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: Rear Shocks
« Reply #2 on: 01 May 2009, 21:06:03 »
Cynic!! ;)
Re: Rear Shocks
« Reply #3 on: 01 May 2009, 21:06:47 »
700? Ffs. Self level shocks aint cheap. 300 retail or 150 on trade club.(see link below for the card) and is almost the easiest job i have done on the omega. Half hour at the most. Or your could just fit standard shocks for £50 and pull the self level fuse...
700 quid my (very hairy) arse!
Bent valve
Re: Rear Shocks
« Reply #4 on: 01 May 2009, 21:09:12 »
Cynic!! ;)
Oh, but its true! they used to earn commission that way. of course, nothing like that could happen nowadays  8-)
seatech
  • gloucester
Re: Rear Shocks
« Reply #5 on: 01 May 2009, 21:11:06 »
they must have been pulling your leg
Saloon with self-levelling suspension                  part number           72119084  retail £110.00 trade £93.53  tclub £70.16
REAL TECH 2 with CANdi
vx trade club
a2reed
  • Battersea London
Re: Rear Shocks
« Reply #6 on: 01 May 2009, 21:13:03 »
Is that £70 per side ? and do I need anything else?
Re: Rear Shocks
« Reply #7 on: 01 May 2009, 21:28:36 »
Yes.
Some spanners.
a2reed
  • Battersea London
Re: Rear Shocks
« Reply #8 on: 01 May 2009, 21:32:57 »
Is there a "how too" anywhere?...is it straight forward?
Re: Rear Shocks
« Reply #9 on: 02 May 2009, 01:08:15 »
before you start check the fittings below and make sure you have the tools needed to undo the top and bottom nuts and bolts.
  You dont need to jack the car. The rear springs will take the weight. Look into the wheel arch on top of the wheel youll see the air pipe with an "R" clip fixing. Remove clip and pipe.
 Open the boot, on top of the wheel arch is a rubber boot covering the shock top nut, remove. Undo the nut, you will seed a smaller spanner(or whatever the fitting is) to the hold the shock shaft still while you turn the nut. Be carefull at this point to note the order the various washers and rubber parts are fitted. Youll need to replicate that order on the new shock, which may or may not have all those parts with them. Re use any you dont have.
Get under the car and undo the bottom shock bolt.
You may need a socket and ratchet for these. Depends if the cup/bolt protector is fitted, mine only had one for some reason? Anyway, remove the bottom bolt and pull the shock out of the inset recess, may need a hammer or lever if its sticks, mine just pulled out.
Fit new shock. From memory.... Iirc extend the shock shaft to full length and push it up into the top shock mount, then, with bolt in the bottom shock hole ready, push the body up until the bolt is at the correct hight and  screw the bottom bolt in. Then fit the rubbers and washers in correct order and fit the top nut.
Re fit the air pipes and R clips. Re double check all the bolts are tight. Then start the car and sit on the boot ledge feet on the floor, and wait for the air pump to kick in to fill the air bladders, you will then feel your feet and legs gradually drop as the car rises. Job done. :-)
Note, working from memory. So may have missed something but its basickly top and bottom bolts and air pipes. What ever order you find things assembled in, obviously repeat when refiting.
p j morgan
  • nottingham
Re: Rear Shocks
« Reply #10 on: 02 May 2009, 01:45:43 »
they were very good  how to do instructions chris. i have them fitted to my elite estate ,has soon has i start her up i get the sound of a compressor coming fom front drivers side under the wing .sometimes it just buzzers like the motor has siezed does this normally happen do you know? thanks pete :y
Re: Rear Shocks
« Reply #11 on: 02 May 2009, 02:13:32 »
hmmm, not had a buzzing from it, never been in there myself, maybe its a bit tired. Give the breakers on here a shout if needs be....
p j morgan
  • nottingham
Re: Rear Shocks
« Reply #12 on: 02 May 2009, 02:24:56 »
thanks chris .had an old lady hit the car two weeks ago going in in the morning for repair to drivers side back door and wheel arch .and bottom panel .i wondered if the bump might have had something to do with it? she hit me with some force shot out of a side street said she did not seeme coming.the wife aquired whiplash to her neck and shoulder and banged her head on the passenger window .i also got whiplash ,could have been worse i swerved  and  excellerated trying to get out of her way. :-?
a2reed
  • Battersea London
Re: Rear Shocks
« Reply #13 on: 02 May 2009, 10:25:56 »
... sounds pretty straight forward .... thanks to everyone here I will not be parting with £700 ... merely £150 ...thanks again
