Pages: 1 [2] 3  All   Go Down
Author Topic: V6 cam follower question  (Read 4360 times)
Re: V6 cam follower question
« Reply #15 on: 05 May 2009, 22:08:01 »
It's a question of whether or not the lobe would hit the stem or not
Just going off Mr Haynes pictures, they certainly look like there's plenty of room. I reckon you'd have heard the expensive noises by now if they don't miss!  ;)  ;)
« Reply #16 on: 05 May 2009, 22:09:14 »
I will not be a happy bunny if I have to strip a camshaft out again ;D
I could swear blind I fitted 24. How odd....
markey mark
  • SLady bitshorpe north lincs
« Reply #17 on: 05 May 2009, 22:09:45 »
it would run at idle but would lose power at high revs and you wouldnt hear any difference i would remove cam cover and check james  :o :o
« Reply #18 on: 05 May 2009, 22:14:03 »
Thinking about it ...... (derrr! :-?) the cam lobe will obviously clear the valve stem, otherwise the lifter would be compressed to almost nothing if they didn't clear each other.
Just guessing .... a compressed lifter is going to e around an inch tall, the lobe only needs a lift of 3/8" or so.
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #19 on: 05 May 2009, 22:16:51 »
some handy pics courtesy of MDTM but nothing conclusive i'm afraid :-/
http://www.omegaowners.com/forum/YaBB.pl?num=1236287115/150
have you got a stethoscope to posibly locate the trouble?
tend to agree with markey mark verdict i.e. more noticable at high revs rather than idle :-/
« Reply #20 on: 05 May 2009, 22:55:39 »
Agreed. It would idle quite happily on 3 valves per cylinder as the throttle is restricting the intake airflow to virtually nothing anyway.
« Reply #21 on: 05 May 2009, 22:58:02 »
Kev - do you agree the cam lobe would also miss the valve stem? :y
(Me thinks covers coming back off, soon  :-[ )
It'll be the first notable balls up I can recall making, if I really have left one out!!
« Reply #22 on: 05 May 2009, 23:08:15 »
As I said earlier, they must do if you think if the effective height of even a compressed lifter relative to the lift of a cam.
He who never made a mistake .........  ;) ;) ;) You'll not do it again!  :y  :y
« Reply #23 on: 05 May 2009, 23:08:56 »
Agreed - everyone is gonna slip up sometime  ::) - but I'll only admit it when I pull the covers off and see one missing  ;D ;D
« Reply #24 on: 05 May 2009, 23:11:22 »
Unfortunately it won't be a 5 minute job fitting it if you have left it out  :( as you well know.
I wouldn't admit it here even if I had left it out!  ::) ::) ::) ;D ;D
« Reply #25 on: 05 May 2009, 23:14:26 »
Just seen this one...
I think, and it's only think, that Markey is right. At idle it wouldn't be particularly noticeable.
And yes, it would probably clear the stem.
Covers off I'm afraid James... Even if we all agreed that it would run like a bag of spanners I'd still have to have the covers off for peace of mind ::) ::)
« Reply #26 on: 05 May 2009, 23:17:37 »
Yep, peace of mind - they are coming off tomorrow ;D  :-[
« Reply #27 on: 05 May 2009, 23:21:28 »
I'll keep my fingers crossed that you find 23 24 of them in there!  :y  :y  :y  :y  :y
Matchless
  • Nottingham
    • A white van
« Reply #28 on: 06 May 2009, 12:15:03 »
Heel of the cam would miss the valve stem and spring cap but I would have thought that the cam lobe would clout it, making lots of noise.
If you want another reason to take the covers off again then a missing follower would leave an open oil delivery hole with reduced pressure to the cam bearings and other followers as a result.
« Reply #29 on: 06 May 2009, 12:17:19 »
As soon as my delivery arrives - I will go to the car and whip the covers off. I am 99% sure all followers are there - but I won't sleep at night until I do ;D
Pages: 1 [2] 3  All   Go Up
