Pages: 1 [2] 3  All   Go Down
Author Topic: Quick Poll! Which to buy DTi or TD ???  (Read 4969 times)
Martin_1962
Re: Quick Poll! Which to buy DTi or TD ???
« Reply #15 on: 08 May 2009, 19:08:06 »
V6 on LPG ;D ;D
Stoph
« Reply #16 on: 08 May 2009, 21:00:46 »
Mine suits me fine, particularly now it's been chipped by the lads on here.
In un-chipped form, they're 130 BHP, and performance is disappointing. Apparently, the chip sends it back to BMW spec of 163 BHP. It's now very good, suits us fine, and locally attains a proven 33 mpg. When towing our 22' caravan, I find that it's slightly lack-lustre in the lower rev range, but kept 'on song' it'll pull like a train. I've modified my driving technique to largely overcome this.
Standard BMW output is 143 BHP
In the 3 series yes, but in the 5 series it was 163bhp
Have to disagree with you Platty... the early 525TDSas fitted in e34 and e39 5 series  is 143bhp, its the later 2001 onwards common rail jobbie thats 163..
Thanks for the comments so far, I think I will find the good in whatever car comes along in the right condition at the right price, I do like low down torque but take on board the possible reliability issues with the dti.... hoping this is only on the poorly serviced ones... Will see if I can get a drive in both over next couple of weeks and see where I go from there... chipping the td for £70 sounds good if I go that way... who do I talk to about that??
Nice busy sight this... plenty to keep me away from work ;)
Cheers
Chris
Stoph
« Reply #17 on: 08 May 2009, 21:02:18 »
V6 on LPG ;D ;D
Still a possible but looking at all the problems with the V6's makes a DTi look a safe bet doesnt it???  :o
Stoph
« Reply #18 on: 08 May 2009, 21:05:42 »
Having never owned a TD i can't comment on them. I have a DTi & it's good, very good. I like the low down torque they deliver & it's a very good town driver, infact it's a good all rounder :y
I've had mine remapped & i haven't found a 2.2 petrol that can keep up yet ;D
thanks Pete... 525 is awful round town as its so slow to pick up under 2000rpm and the gearing is so high... however 80 on the motorway is incredibly relaxed... unfortunately with teh amount of traffic on the road these days steady cruising dont happen often....
Who did  the tweaks on the DTi for you and what would I be looking at cost wise?? guessing its about 25% more bhp and torque if its similar to the ads have been looking at...
Chris
Martin_1962
« Reply #19 on: 08 May 2009, 21:11:54 »
V6 on LPG ;D ;D
Only problem with mine is valve seals and worn thermostat
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #20 on: 08 May 2009, 21:15:05 »
Cheers
Chris
I thought so too !  Mine should be delivered Monday. I'll post up what I think of it.   :y
waspy
« Reply #21 on: 08 May 2009, 21:17:50 »
Chris
Where's your location?
http://www.zen19051.zen.co.uk/ This guy. He's very good :y :y
« Reply #22 on: 08 May 2009, 21:43:45 »
I would have the 2.2 4 pot over the 6 cylinder over rated BMW lump everyday of the week
Stoph
« Reply #23 on: 09 May 2009, 09:53:01 »
Chris
Thanks Pete....... Asbourne only about 30 miles... :)
golden_delicious
  • Kingston upon Hull
« Reply #24 on: 09 May 2009, 10:12:00 »
Bit of a late comment but our experience of 2.2dti contradicts most of the comments made on here.ours has been outstanding apart from a couple of electrical/sensor issues although i must add it did die quite abrubtly @ 401k when the timing chain broke (really should be a service item along with the bottom pulley which seems to last 130-160k). :-/
Our 'newer' engine has been in for 8k now so far only needing a new crank sensor :) :) :y
There are only 10 types of people in the world, those who know binary and those who dont ;-)
Grrrrrr
  • Buckinghamshire
    • Jaguar. WTF have I done?
« Reply #25 on: 09 May 2009, 12:26:12 »
Oddly enough the bloke living behind me has the newer 2.2 Signum and his injection pump failed the other day. Never had it on a Vauxhall before but the garage says it happens quite a lot on the newer Vauxhalls.
I'd go for the older one. Someone on here might be able to advise if it can handle home-grown biodeisel or not!
Work is the curse of the drinking classes (Oscar Wilde)
« Reply #26 on: 09 May 2009, 12:50:46 »
Injection failure is directly attributable to servicing.....90% of the time they fail due to the fuel filter not being changed and drained of water and this happens on all manufacturers cars
« Reply #27 on: 09 May 2009, 13:28:52 »
I suspect its a pretty standard injection pump anyway, not GM specific.  That said, I've heard of a couple of cases of this now, so is certainly something to bear in mind, whether caused by poor components, or GM's daft service schedule....
Stoph
« Reply #28 on: 10 May 2009, 10:14:29 »
I think if I had run an engine to 401k without major problems I would have had my moneys worth!! So the answer so far is.... no idea! Several votes more for the old BMW lump but a few very positive comments on what the DTi drives like with most of the issues down to servicing(or lack of) Looks like I'm gonn ahave to make time to go drive some and see how they feel ::)
Thanks for all the input, will let you know how the test drives go...
Chris  ;)
omegaman2
  • Kilsyth, Glasgow G65
  • cruise , tints, shinbuster,advanced drinking test
« Reply #29 on: 10 May 2009, 11:24:27 »
my2.2dti pulls the caravan wiyh ease
recent run from wales back to scotland 36mpg till i hit side winds then 32mpg for the last 150 miles
very powerfull  :y
dieseldonicely
Pages: 1 [2] 3  All   Go Up
Page created in 0.038 seconds with 16 queries.
