Pages: 1 2 [3]  All   Go Down
Author Topic: How hard is it to fix Faulty exhaust valve on V6?  (Read 6475 times)
NiallyV6CDX
  • County Down
Re: How hard is it to fix Faulty exhaust valve on V6?
« Reply #30 on: 07 May 2009, 13:06:19 »
No, completely normal from a cold start.
kentman99
  • Orpington, Kent
« Reply #31 on: 11 May 2009, 00:39:41 »
Before I forked anymore dosh I thought i'd do a crafty one and get the mrs to call the rac to have a look a look. The only problem was that I was at work when they came so didn't get to grill the fella!  Anyway the report he left said the engine was misfiring and only running on 5 cylinders with a blow from the exhaust. He suggested getting the car serviced.
NiallyV6CDX
  • County Down
« Reply #32 on: 11 May 2009, 16:20:26 »
Yes, that sounds about right. did you check the spark plugs/ ignition leads?
Also a compression test while doing the spark plugs would uncover or rule out any major mechanical faults with the engine.
kentman99
  • Orpington, Kent
« Reply #33 on: 11 May 2009, 23:51:53 »
oh no now you're worrying me....   the garage that told me it was a faulty exhaust valve never came back to me when I enquired as to whether they did a pressure test. I was really hoping that a rocker cover gasket, plugs and leads change would mean problem solved. I got the impression that if this didn't fix it then the likelyhood is that its the dispak that's the problem.
omega rick
  • witham essex
« Reply #34 on: 12 May 2009, 09:49:18 »
you must have a compression test carried out to identify the problem , your just going round and round in circles untill you know whats the problem you cant come to a cure
kentman99
  • Orpington, Kent
« Reply #35 on: 12 May 2009, 12:47:01 »
Ive spoken to the guy who's doing the work and asked him to do a pressure test aswell.  Presumably it would make more sense to do that before carrying the other work?? Ive read on here about percentages when doing the pressure tests, can someone explain what that means?
omega rick
  • witham essex
« Reply #36 on: 12 May 2009, 13:08:00 »
a compression test is a pressure test , the readings should all be within 10% of each other
Pages: 1 2 [3]  All   Go Up
