Author Topic: Running lumpy?  (Read 3459 times)
big-o-bob
  • Yorkshire
Re: Running lumpy?
« Reply #15 on: 12 May 2009, 21:26:52 »
Problem now solved.
What a plank I am :D
I had infact, not plugged the injector connection in properly after removing to replace the oil cooler.
I have just removed the plenum (I am fantastic at this now), and plugged it back in.
I have not had chance to do another paper clip test yet (It started getting dark), but I suspect that it will have cleared at least 2 of the codes.  as for the MAF sensor code - if it is still on, I will probably be back later.
The car now runs a smooth as a nut, so hopefully no codes will be showing now.
Thanks everyone :y :y :y
