Author Topic: High lift trolly jack  (Read 3688 times)
Pete Elite
  • Uxbridge, Middlesex
Re: High lift trolly jack
« Reply #15 on: 14 May 2009, 23:57:57 »
Thanks for the advice fellas.  I have a small trolly jack in case that i have used with no problems but i wanted one that i can get the car up higher with as to get my axle stands under and the one i have seen gets up to 800mm so thats plenty high.  Just thought i would check before spending out heaps of cash.....
   How high do your stand go up to?
« Reply #16 on: 15 May 2009, 00:39:27 »
im under the impression, rightly or wrongly, that in order to get car on stands reliably, you may well need 2.25 ton jack as a minimum. Have had the use of 3 smaller 2ton jacks and non had the hight to reach the lowest stand setting, one bent side ways quite badly as i have a rather breaked tarmac drive and the wheels dont role as its pumped up.
I now have a 3 ton quick lift jack which easily lifts to the top/highest stand setting and its well up to the job but is VERY heavy, unnecessarily so. 2.25 or 2.5 ton would be more suitable i would have thought. In my experience anyway. Hth
Having said that Mr Bs pictured small jack is doing bloody well lifting "ALL" that weight.  ::) :-X
gstylebaby
  • stockport
« Reply #17 on: 15 May 2009, 02:11:46 »
Your right mate when i put the small trolly jack under and get the car up i can only just get the stands under and thats on the first setting.  The high lift one that i have seen is only 2 ton but thats what my small one is and that lifts it o.k just not that high.  My axle stands are 3 ton ones.
« Last Edit: 15 May 2009, 02:12:15 by gstylebaby »
p j morgan
  • nottingham
« Reply #18 on: 15 May 2009, 02:21:37 »
i managed to get my hands on a good jack .i got from the local tyre and exhaust center .they had just replaced all the jacks and they were selling the old ones still in good condition got mine for twenty quid .you could say i was in the right place at the right time.it lifts my landcruiser with ease and thats three ton  :y
gstylebaby
  • stockport
« Reply #19 on: 15 May 2009, 02:32:11 »
Now theres an idea....Mite pop round a few tyre places and see if any one has anything????
p j morgan
  • nottingham
« Reply #20 on: 15 May 2009, 02:44:08 »
worth a try .apparantly they have to change them every length of time for safety reasons give a go and good look :y
« Reply #21 on: 15 May 2009, 07:48:31 »
Having it load tested with ALL that weight reassures me that it'll cope with a wheel change on my caravan!  ::)  ::)  ::)
« Reply #22 on: 15 May 2009, 09:45:05 »
He he. :-) will be fine for the Job then. It survived the Jamie test.  ;D
