Author Topic: MID issue  (Read 1736 times)
nathans
  • south east
  • I live here, there and everywhere
MID issue
« on: 19 May 2009, 22:46:35 »
ok started working on the miggy today again
and was focusing on the electrics
I have sorted the outside temp fault (thanks for the advice on this forums) It had been unplugged.
however still cant get rid of the F on range
any advice on likely cuase please
thanks
nathan
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: MID issue
« Reply #1 on: 19 May 2009, 22:55:00 »
The F on Range is probally a gearbox sensor to the MID. Or Someone in its prevoius life has swopped the MID from a Auto into a Manual or vise versa.
What happens when you fill it up with fuel?, does it show 0 range before going to F.
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: MID issue
« Reply #2 on: 19 May 2009, 23:01:20 »
F on range is something to do with the fuel level sensor :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: MID issue
« Reply #3 on: 19 May 2009, 23:03:50 »
I had the same problem a couple of years back sure it was the MID though
zirk
  • Epping Forest
Re: MID issue
« Reply #4 on: 19 May 2009, 23:04:34 »
Agreed, but Ive had this on incorrect MID swop outs, as well as gearbox sender, which is what I would confirm first  :y
nathans
  • south east
Re: MID issue
« Reply #5 on: 19 May 2009, 23:13:31 »
ok when i got the car there was a old screen in the boot
and one on the dash
so I would then lead to the conclusion in is the wrong one
i will take it out and read the numbers and see
i will also test the one from the boot
thanks guys will keep you posted
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: MID issue
« Reply #6 on: 19 May 2009, 23:15:22 »
you will problably find the one in the boot is pixalated
nathans
  • south east
Re: MID issue
« Reply #7 on: 19 May 2009, 23:17:12 »
well hopefully it will show me enough to prove it was an original
in which case i will need to hunt for another one to match it
thanks
« Last Edit: 19 May 2009, 23:17:26 by nathansky »
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: MID issue
« Reply #8 on: 19 May 2009, 23:18:03 »
there failry easy to replace!
btw anyone from an Astray G or a Vectra B will work too
The Boy & the other T2 members can also reprogram that one in your car for you
see
http://theboy.omegaowners.com
« Last Edit: 19 May 2009, 23:19:04 by tmx »
nathans
  • south east
Re: MID issue
« Reply #9 on: 19 May 2009, 23:24:29 »
thanks will keep that in mind
 8-)
