Author Topic: How to fit ECU unit? 2.6 v6  (Read 1730 times)
colin28
  • Southend-on-sea, Essex
« on: 22 May 2009, 10:54:26 »
My ECU Engine has gone! I have been quoted £840 new or £100 used.
Can anyone please help with how to fit one of these? or shall I let an experienced person do it?
How easy is it to change?
Thanks
Re: How to fit ECU unit? 2.6 v6
« Reply #1 on: 22 May 2009, 11:36:25 »
Who says the ECU has failed? Never, ever seen one of those fail.
Symptoms?
Martin_1962
« Reply #2 on: 22 May 2009, 12:06:59 »
Anyway if they have gone you get them repaired.
colin28
« Reply #3 on: 22 May 2009, 12:19:42 »
I have had loads and loads of problems since I had the gearbox changed 3 months ago.
Was strongly pulling back when you put your foot down to accelerate. Engine management light always on and flashes.
Fault codes
0130
0300
0301
0303
0305
I replaced the coil several times still says faults.
Changed camsaft sensor as was told this could be the problem
Changed sparkplugs
Still driving very very bad.
Been in the auto electrcians for the last 3 days as they tried to find the faults.
Got a call this morning from them saying all ignitions and coils are perfect and the last thing it can be it the ECU unit.
« Reply #4 on: 22 May 2009, 12:43:23 »
Fault codes
0130
0300
0301
0303
0305
Changed sparkplugs
Has the throttle body been cleaned?
Engine Earths all OK?
Also, the misses are all on one bank, which would lead me to suspect a local issue to that side.
Martin_1962
« Reply #5 on: 22 May 2009, 13:35:21 »
Check cam covers on that side - sounds like plugs or coil pack on drivers side bank.
MutantCav
  • Gainsborough
« Reply #6 on: 22 May 2009, 14:07:11 »
Who changed the gearbox for you...seems if the problems started at that point its something they did
« Reply #7 on: 22 May 2009, 14:41:44 »
Whoa, hang on.
Has this had a box swap, in particular a gearbox conversion?
colin28
« Reply #8 on: 22 May 2009, 16:04:11 »
The auto electricians checked the coils, plugs, injectors and everything is perfect!
The car has been with them the last few days as they have been searching for the problem to the misfire.
There conclusion is the Ecu.
I want to get the Ecu changed so I can get an mot and sell the car! I have been advertising it locally as it is for £1,000.
But I know I can get nearly double if I spend the 200-300 to get fixed. but am happy to sell cheap as Iknow nothing about cars.
colin28
« Reply #9 on: 22 May 2009, 16:06:14 »
Whoa, hang on.
I have no idea as I know nothing about cars only how to drive one.
I am only going by what the Auto electrician said.
I have spent £800+ the last 3 months trying to get the faults sorted.
« Reply #10 on: 22 May 2009, 16:36:59 »
Well I hope you are billing the muppets who did the clutch!
Send the ECU for repair.
colin28
« Reply #11 on: 22 May 2009, 17:11:54 »
How and where can get the Ecu repaired?
MutantCav
  • Gainsborough
« Reply #12 on: 22 May 2009, 20:15:54 »
3rd post in the thread TB...
Reply #3 - Today at 12:19     I have had loads and loads of problems since I had the gearbox changed 3 months ago.
